KR8 KR8 is offline
3.0sc - split case or not?
Gentlemen,
Quick run down…I started out just wanting to clean up a 3.0 that is going into my 76s. After pulling the lower valve covers I discovered one barrel nut. Not Good.
Now I’m in deeper ($$$) than I want to go at this point. I wanted to save the money for the full rebuild on the 2.7 that is in the car now. I know things change – while you are in there do this and do that. So, I have a few questions and need your input on. Do I split the case and do a full rebuild on an engine that has 80K+ ran very good before pulling out of a 83sc?
I've pulled the camshaft housing/heads and all the cylinders look great.
I’m thinking that I’ll send them and the pistons into German Precision just for a second opinion with a good cleaning and what ever they suggest I do. I will be replacing all of the bottom studs with steel ones (?). Beside all of the other seals and gaskets, O rings, oil tubes, oil cooler ultrasonically cleaned, etc, etc... that go with rebuild any other suggestions?
Here are a couple pixs to see what I have;
Thanks for the help,
Old 09-16-2009, 08:37 PM
I just split my 3.0 yesterday. All I had was one broken head stud to lead me to this point. I had gotten tired of contemplating if I should or shouldn't, so I figured With the Winter season approaching I might as well. This way I could check everything out, Reseal case, clean case ( in case I contaminated it upon tear down), Replace #eight o-ring and main and intermediate bearings.
Then my 3.0 ,107,000 mile engine shall be leak free.
Everything looks like new within the case except perhaps the intermediatee bearings.
The one frightening thing was hammering the case to split it. Think next time a block of wood is in order.
Anyhow, best of luck to you.
Leakproof.
Restoring/Rebuilding Yellow Canary '79 911SC
Suspected track car
Old 09-17-2009, 07:35 AM
I just split my 2.7 case because that seems to be the encouragement (and because I got some dirt/debri in the case during tear down - the engine was a complete dirty mess). Inside the bearings look smooth, the crank was within specs, etc. In hindsight, I wish I was better about keeping dirt out of the case and then I would not have split it. Split it can lead to another $600-$800 cost. Of course if you listen to everyone, that cost will go up to about $1,000 to $1,200. Just a thought.
Old 09-17-2009, 08:15 AM
Also,
I unfortunately or fortunately discovered I have Alusils. Two machinist told me within seconds without measuring, just to go ahead and re-ring without plateau honing, as discussed in great detail on this site. However the owner did mention to my surprise this type of honing to bring the silicon crystals back to the surface.
Also cleaned off all the carbon from the piston domes.
Had my heads completely re-done and had engine tin powder coated.
Also planning on having trans rebuilt.
Boy, did I get my self in deep on a perfectly running car. To late to turn back now. I am getting quite an education and a cool collection of tools.
Leakproof.
Suspected track car
Old 09-17-2009, 08:32 AM
Home of the Whopper
You can pull a rod bearing without splitting the case. See what it looks like, then decide if you want to go any further.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 09-17-2009, 08:56 AM
But there is a certain confidence in knowing what is inside the case and new sealant on the halves.
Bruce
Old 09-17-2009, 09:01 AM
T77911S's Avatar
its next to impossible to keep it clean for any period of time. i put a plastic bag over mine after removing the pistons, i was not going to split the case. i pulled the bag off to check something and found sand where the cylinders slide in. i thought at first about removing the sump pan and washing it out, but my porsche guru advised me to split the case and check everything and reuse if good, he did not know about the sand, but he too also mentioned how he hates to have one partially apart/toghter and sitting because of dirt.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-17-2009, 09:33 AM
KR8 KR8 is offline
Thanks for the reply
Leakproof – I’m sitting on the fence also with the winter coming up, what the heck is an extra $1500 at this point to split the case and put it all back together. Plus I think by splitting the case… with a block of wood, knowing once I had it back together everything is good for another 100,000+ that’s for Bruce (Thanks!). As for the tools – yes I’m collecting a good set to.
tadel001 – In the time I have everything apart I’m sure I’ll have some kind of foreign objects in there, thanks for the input.
BK911 – how difficult is pulling a rod bearing without splitting the case?
Thanks guys!
Old 09-17-2009, 01:02 PM
Dr J's Avatar
It's always tough to make these decisions, but with 80K miles, I wouldn't split the case. These motors are very strong. Opening it up will only take you in deeper money wise and in disassembly/reassembly time. Put it back together ASAP and use it. Ask the same question in this forum after another 100k miles are added.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 09-17-2009, 03:41 PM
Home of the Whopper
That's sorta what I am thinking, as long as it was kept clean. Look in the cylinder hole. See the two nuts holding the rod together? Remove them and pull the rod apart. Check the bearings. If good, put 2 new rod bolts in and torque it back up. If no good, split the case.
Old 09-18-2009, 09:50 AM
KR8, It's funny, about a month ago I was asking the same question about removing the rod without splitting the case. Anyhow it takes about five minutes to remove a rod if that. Very simple indeed.
Spoke to a machinist today and he said splitting the case is the only way. In fact he's the second machinist to say this.
Definitely not trying to pursuad you either way. Theres really not that much left to disassemble, just more money, education and decisions once in.
I think I'm actually glad I did it. Kind of a relief in a way.
Leakproof.
Suspected track car
Old 09-18-2009, 07:04 PM
OldTee's Avatar
I would say the decision to split is different for a 3.0 case than a 2.7. Aluminum vs magnesium I should say. For a 3.0 with a broken stud that otherwise runs ok, just fix the stud and go on for another 30-40K miles, and IF, no other problems are showing such as leaks, oil pumping and burning, knocking. Spend your money updating the chain tensioners. Now, if you are looking for a long, expensive, interesting project ... go ahead.
Old Tee
all 911s sold
Old 09-19-2009, 06:29 AM
KR8 KR8 is offline
Still open but more on the side of not splitting
Thanks All, I've talked to a lot of porsche people in the last couple weeks; at this point everything looks good - no need to split. Even in Wayne's book he mentions that if nothing is wrong accept a broken head stud I should get another 100,000 additional miles or more out of the rings, cylinders and pistons. I'll send some pixs when I get back into it.
Old 09-21-2009, 04:38 PM
KR8 KR8 is offline
Alusil Cylinders
Need help, at this point I'm going to take my camshalf housings - head assembly for inspection and evaluation to German Precision. At the same time I would like to take my Alusil cylinders and pistons for the same thing plus cleaning. Again, I'm trying to stay away from splitting the case. In our host book he recommends not to pull the pistons out of the cylinders and do not dislodge or disturb the rings. OK how the heck do you do that?
Sure I can set the piston as high a possible - pull the cylinder up as high but not past the first ring to expose the outside wrist pin but how do you get the inside one? The next cylinder is in the way. Help??
Old 10-28-2009, 06:33 PM
You can't measure the pistons and rings if you don't remove them from the cylinders. Personally I would take them out and just keep the same pistons and rings with each cylinder. Mark them so you don't get them mixed up. If you use the old rings it will not matter that you've "disturbed" them. I suspect that with the miles you have they will measure up just fine. Whenever I've bought new rings they measure as bad or worse than the old rings.
The wrist pins will come out easier if you heat the pistons with a propane torch.
-Andy
Old 10-28-2009, 09:51 PM
KR8 KR8 is offline
3.0sc - split case or not? Alusil Cylinders
Hey Andy, thanks for the input. I'll get back to this next week, take a couple pixs for the page to keep it running. I'm sure I'll need more help down the road.
Old 10-29-2009, 11:21 AM
I couldn't remove my pistons & cylinders as a set either.
Those piston pins did not come out as easily, as Wayne said in his book.
After separating them I finally discovered (on my own) to heat the piston with my torch (I am a plumber) Not kidding, the pins basically fell out at that point.
Then I discovered in one of my books that it's S.O.P to always use heat when installing pins! What a shock.
Leakproof.
Suspected track car
Old 10-31-2009, 12:14 PM
Also, I just finished removing all my rods from the crank and there are defiantly two rod bearings that are scratched and worn, glad I did this.
The crank also has some scratches to match where the worn rod bearings sat. Hopefully this can be ignored.
I was thinking of re-using my old rings too. A Friend is advising me against that.
A Porsche expert told me to pull the #5 rod at the very least, to inspect bearings, because this is the last one to receive oil,
And by the way, my main bearings looked perfect (to me) But was advised by P-people to replace anyway. Intermediate bearings understandably questionable.
Always happy to share info learned,
Leak Proof.
Suspected track car
Old 10-31-2009, 01:44 PM
relayswitcher's Avatar
Send a message via Skype™ to relayswitcher
KR8,
It's always hard to know what to do with opinions pro and con. IMHO I'd balance out the amount of hours vs the money spent. I'm of the school where if you have the engine down to the point you do, it's wise to get it done from the crank out. You've put hours into it, invested. Split the case for saving time and money. My point is....you put it back together without the split, who's to say it won't do something unexpected just 100 miles down the road..... then you'll think to yourself...all that work I just did cutting corners and time just went down the drain....(40-50hrs depending on your expertise)...and now I have to do it twice another 50 hours or more. Bearings are not that much and the intermediate shaft bearings?...just a few dollars. Rebuild the engine completely and have the confidence of knowing what's in there while you are driving along and not fear the next stud bolt will come back to haunt you. In addition, the 2.7 gets a bad rap but is a good motor if done correctly, but moreso a 3.0 SC is notibly one of the more dependably built by porsche of the air cooled.
Rebuild it and have peace about it...not worry. Good luck to you bud.
Old 10-31-2009, 08:01 PM
KR8 KR8 is offline
German Precision
Thanks Guys, I dropped off my heads, piston, etc. at German Precision yesterday. Ted seems to be a great guy and really easy to talk to. After his initial inspection all's good. Once he has preformed a good cleaning he'll know more. He suggested that I do not touch the ring with the LS unless after cleaning something looks bad. I hope not things are starting to add up. I've order 12 new steal head studs through our host for the bottom row. I'll try to get started on this in the next couple weekends. I don't think I'll really have an issue with them except for the broken one.
I'll up load some pix the next time I chime in.
Later...
Old 11-05-2009, 06:54 PM
