ovesize bearings to a 2.7 block? where?
is there a company that sells oversize main bearings for a 2.7 block?
havent found any...is it worth the hassle?
the block is othervise good, but my guess is that it needs some machining.
the block is in stock size.
i would have a possibility to use a 901/02 block or a 901/09 block instead...
for a screamer project...with 90mm high comp slugs.
what would you do?
thanks for any info
Old 10-28-2009, 07:16 AM
If your looking for oversize bearings for a ground crank they are available here and other suppliers. If you need oversize for a line bored case I believe they can only be purchased from the Porsche dealer.
Old 10-28-2009, 09:00 AM
Hmmm, its for the block. So i have to ask, from Porsche dealer then. Thank you! :-)
Old 10-28-2009, 09:20 AM
Thats not a 2.7 block..
Bruce
Old 10-28-2009, 01:30 PM
Bearings for an oversized mainbore OR an undersized crank are priced like gold.
I have a perfect .01" under crank that would make a nice lamp.
JPIII
Early Boxster
Old 10-28-2009, 04:29 PM
Bruxe is right. Thats my 68 s block. But the whole thing sounds like 911 blocks are not so great to rebuild... :-(
Old 10-28-2009, 10:47 PM
Irrationally exuberant
ChrisBennet's Avatar
Instead of increasing the size of the mains and using oversize bearings ($$) you would do better to just have the case resized.
Resizing = taking a little off the case halves and reboring the shaft holes back to standard.
Competition Engineering or Ollies can do it for you.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 11-02-2009, 10:22 AM
-Chris
Chris is right on,....
Thats the proper way to fix these cases.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 11-02-2009, 11:49 AM
great to know, but im located in europe :-( sadly. i have to ask from the machine shop. if they can do it. thanks again. maybe getting a different block would be the best thing?
Old 11-02-2009, 03:05 PM
