ovesize bearings to a 2.7 block? where?
is there a company that sells oversize main bearings for a 2.7 block?
havent found any...is it worth the hassle? the block is othervise good, but my guess is that it needs some machining. the block is in stock size. i would have a possibility to use a 901/02 block or a 901/09 block instead... for a screamer project...with 90mm high comp slugs. what would you do? ![]() thanks for any info
If your looking for oversize bearings for a ground crank they are available here and other suppliers. If you need oversize for a line bored case I believe they can only be purchased from the Porsche dealer.
Hmmm, its for the block. So i have to ask, from Porsche dealer then. Thank you! :-)
Thats not a 2.7 block..
Bruce |
Bearings for an oversized mainbore OR an undersized crank are priced like gold.
I have a perfect .01" under crank that would make a nice lamp.
JPIII Early Boxster |
Bruxe is right. Thats my 68 s block. But the whole thing sounds like 911 blocks are not so great to rebuild... :-(
Irrationally exuberant
Instead of increasing the size of the mains and using oversize bearings ($$) you would do better to just have the case resized.
Resizing = taking a little off the case halves and reboring the shaft holes back to standard. Competition Engineering or Ollies can do it for you. -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
![]() Thats the proper way to fix these cases.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
great to know, but im located in europe :-( sadly. i have to ask from the machine shop. if they can do it. thanks again. maybe getting a different block would be the best thing?
