efhughes3's Avatar
Thanks Jeff. The hard part is over, the heavy spending is done!
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 02-05-2010, 09:56 PM
SAIGON 68
johnnywishbone's Avatar
email sent
Old 02-11-2010, 09:31 AM
efhughes3's Avatar
Well, finally, the work has started. Got the engine out via a garage party yesterday:
Started stripping it down today. I'll do some exterior cleaning next weekend before opening any of the internals up. I'm not opening the case, so cleanliness will be a prime concern. It's almost harder doing it this way than stripping everything down and making it as new, then building up from there. Everything that bolts to the case will be made as new, but again, caution is prudent.
Ed Hughes
2015 981 Cayman GTS
Old 02-21-2010, 01:33 PM
efhughes3's Avatar
Well, how is this for a bit of a sobering surprise? My motor mount or console is severely cracked. It looks like heat treating gone wrong. Interesting to note, Pete Zimmermann relayed to me that he saw this happen to a few '84's, maybe Targas, a number of years ago. It was bad enough that they made it a point to inspect the mount on any car they worked on. I've had Ruby's engine out twice, the most recent two years ago-no issues were evident at that time.
Or, I can say I'm thinking it was the severe torque she already put out, coupled with my driving extracting the most out of her...
At any rate, something to look out for:
Ed Hughes
2015 981 Cayman GTS
Old 02-24-2010, 03:10 PM
Wow Ed, good news/bad news deal. Expensive item, (aren't they all on our girls?)
O2 In Sully We Believe
Old 02-24-2010, 03:27 PM
efhughes3's Avatar
Only expensive new...I found several for $75. I'm just going to make sure and keep an eye on this when the motor is back it.
Ed Hughes
2015 981 Cayman GTS
Old 02-24-2010, 03:36 PM
very cool. When I had the 3.6 rebuilt the shop welded a gusset on the right, (passenger side), support. I guess they've seen that side break from the torque.
Old 02-24-2010, 03:41 PM
efhughes3's Avatar
Hmm, that is interesting. I may check into this. The fact that this cracked like this would lead me to believe it is high strength steel or heat treated, which means I'd not be quick to weld myself. But worth exploring, thanks Mark.
Ed Hughes
2015 981 Cayman GTS
Old 02-24-2010, 03:44 PM
Ed, I looked at the build sheet. He say they 'modified the rear engine hanger'. I'll go into the garage and see if I can get a picture.
Old 02-24-2010, 04:13 PM
Opps you are talking motor mount. Could still be worth looking into depending on what kind of torque you are going to have. I believe Silin is at 258.
Old 02-24-2010, 04:15 PM
Modified rear hanger
Here it is Ed. If you'd like I'll talk with the shop and find out what all they did. I believe they cut a wedge out then fit the gusset. May be mistaken.
Old 02-24-2010, 04:28 PM
efhughes3's Avatar
Ahh, I believe I've seen beefed up horizontal bars. Mine is the chunk that bolts to the case and covers the crank pully. I've called it the "motor mount", but I think PET calls it a "console".
Ed Hughes
2015 981 Cayman GTS
Old 02-24-2010, 05:03 PM
Mine was cracked on my '78 SC but not as bad. I had the crack ground out and TIG welded. Cost about $30 to fix and it's right. I don't believe the part is heat treated.
Lindy
Old 02-25-2010, 06:43 AM
efhughes3's Avatar
Thanks Lindy, nice to know someone else has seen this. I should probably post this on the main forum. Good warning for folks to inspect theirs.
Ed Hughes
2015 981 Cayman GTS
Old 02-25-2010, 07:50 AM
efhughes3's Avatar
Last night, I ordered a few hundred $ worth of misc from Pelican Parts. Today, I took the headers off, gave her a sponge bath with several cans of CRC brake cleaner, took the camlines, oil cooler and valve covers off-then "bled" her. Tomorrow I'll hopefully get her stripped down to a shortblock and then work on cleaning the head and cam towers. Then-start going in the other direction. It amazes me how many part come off these suckers!
Ed Hughes
2015 981 Cayman GTS
Old 02-27-2010, 03:52 PM
johnman001's Avatar
Good looking engine. Makes mine look filthy. What are you going to do with your existing P/C?
John Flesburg
2016 981 Boxster S.................| 1983 911 Turbo - (White)
1974 911 3.2 - Red Car........... | 1974 914-6 3.2 - (Silver)
1974 914-6 3.2, GT -(Red).......| 1974 914 - 2.7 GT Clone (TBD - Saphire?)
1971 914 (TBD)..................... |
Old 02-27-2010, 09:26 PM
efhughes3's Avatar
Today, I removed the cam drive hardware, chainboxes and head/camtower units off today. I really goofed up though-almost. I didn't pull the dowel pin from the cam sprocket like I meant to before pulling the sprocket. I immediately remembered it when I got the sprocket off the cam, and it was MIA. I was sorely disappointed in myself. I tipped the motor on end, and reached into the case with a magnetic pickup to try and nab it, but got nothing. I tapped on the bottom of the case gently to try and dislodge it, but that didn't do it. I was well into my vulgar vocabulary when it came rolling out of the case and onto the ground. Got to be more careful!! I also pulled the clutch which looks great after 17,000 miles and 5 years.
No progress until next Saturday. I'll take the heads apart then, and get a plan together for cleaning them. I'll probably take them to a shop for cleaning. I may then put the new p's and c's in too.
Ed Hughes
2015 981 Cayman GTS
Old 02-28-2010, 07:42 PM
efhughes3's Avatar
John-I haven't gotten that far yet in my thinking.
Ed Hughes
2015 981 Cayman GTS
Old 02-28-2010, 07:43 PM
Jeff Alton's Avatar
Ed, looking good!
What type of floor is that in the garage?
www.turn3autosport.com
Old 02-28-2010, 09:01 PM
efhughes3's Avatar
Originally Posted by Jeff Alton View Post
Ed, looking good!
Thanks Jeff
It is Racedeck tiles. So far-so good after almost two years. Mops up every 6 months and looks new. Floorjacks and jackstands do need some protection.
Ed Hughes
2015 981 Cayman GTS
Old 03-01-2010, 07:36 AM
