Cylinder Head Temp Sensor
I am in the process of updating my 930 engine to EFI and noticed that it doesn't have provision for a CHT sensor. I brought the engine in a disassembled state and believe it is a 1986 vintage.
Is there any way to install a CHT sensor or do I need to have the head machined to accept the OEM sensor?
Thanks in advance,
Richard.
RSR Replica - http://forums.pelicanparts.com/porsche-911-technical-forum/472762-rsr-update.html
930 Cab - ex-IA car, 3.4L, 1.2 bar, G50
996 Turbo - X50.
Old 01-19-2010, 08:27 PM
Puny Bird
Mark Henry's Avatar
The VDO head temp sender might work, it's thermocouple just replaces the washer under a spark plug.
Then you would have to find a home for the gauge.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 01-20-2010, 05:55 AM
timeless beauty
rcaradimos's Avatar
Thanks in advance,
Richard.
OEM sensor goes on cylinder #3
Head Temperature Sensor Replacement
Bob
87 targa
Old 01-22-2010, 07:04 PM
What tuning parameter are you looking for this to control? Also, just curious, what EFI setup are you using? On our 356 EFI build we’re using an oil temp sensor, both for warmup and for a tiny bit for over temp protection. Because of the time it takes the mass of a cylinder head to heatsoak, and thus change temperature, I don’t think that you will gain much by pulling boost or dumping more fuel once the head is overheating. (FWIW, I don’t think using oil temp is a good medium to use either for overheat protection, but better than nothing, and I can trigger a dash light with it). I think you’d be fine if using this for the warmup cycle, but then why not just use oil temp for this?
1960 356 Super 90 - EFI'd
1989 190e 2.6
1991 964
Old 01-28-2010, 02:03 PM
Thanks for the response guys.
I am in the process of building a twin turbo 930. I was planning on using a Motec M600 however due to some issues with my engine builder, I may end up using a Haltech P2000 (long story). I also have a J&S knock control unit.
I will be running a crank and cam sensor for full sequential. I plan on using MAP and was considering a CHT sender for both warm-up and over temp. I plan on running moderate boost (~1.3bar). This is a high end build with new everything including Carrillo rods, 993TT manifold and billet injector risers.
The engine is at a long block stage - before I realized that it did not have provision for the CHT. I was wondering if it is worth removing a cylinder head and if it is possible to have it machined to accept an OEM CHT sender? Or if there is an easier way to monitor over temp protection?
Richard.
996 Turbo - X50.
Old 01-28-2010, 08:36 PM
I think an oil temp sensor would save you at ton of money and work. Would the CHT get you anything an oil temp sensor wouldn't?
1989 190e 2.6
1991 964
Old 02-01-2010, 10:37 AM
brads911sc's Avatar
On CIS engines there are three temp sensors that are all unused when removing CIS. One on each chain cover and another on the breather cover. I would think you could use one of those ports... right?
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 02-01-2010, 12:56 PM
sjf911's Avatar
I've tried all of those locations and found CHT to be the best for EFI purposes, especially warmup and hot start.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 02-01-2010, 01:54 PM
After thinking about it some more, being a dry-sump motor, your head (or block, or intake manifold) will heat soak faster than all that oil held in a remote tank. Given that, you may want to use a washer type thermocouple attached to the head or on the intake manifold. You can use the adjustable warm-up cycle slope to compensate as necessary. I think you could dial it in using an oil temp sensor, but it might be more difficult.
1989 190e 2.6
1991 964
Old 02-03-2010, 03:22 PM
930gt-40r's Avatar
On my car (efi 930 with accel dfi and soon to be Platinum 2000) I use oil temp for the correction. I am running an oil filter cousel on my motor instead of the oil cooler, so my engine thermostate is no longer needed. Now that I have the block off plate there, I simply drilled, tapped, and ran the 3/8s GM CTS right there, and that paints a pretty accurate picture for the ecu.
I could see a potential conflict in extremely cold conditions, although I have never had a drivability issue as a result of it.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 02-03-2010, 03:39 PM
