11.3:1 Compression ratio fuel requirement
Twin plug heads, PMO carbs, air fuel ratio gauge in the cockpit. Should I run 100 octane? Race car use.
82SC Track Car |
Try not, Do or Do not
As posted before: Detonation is a function of a plethora of conditions. compression ratio (dynamic compression being key) combustion chamber configuration piston dome configuration ignition timing Octane head temperature altitude fuel : air ratio intake charge temperature.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
I found some useful charts at: Daytona Sensors LLC - Tech FAQ Engine Tuning
It looks like you should be safe with 100 octane and twin plugs. -Andy
72 Carrera RS replica, Spec 911 racer |
Cam specs would help.
82SC Track Car |
82SC Track Car |
The cams match the motor specs. They are a custom grind.
82SC Track Car |
They see higher loads, higher temperatures with missed shifts and sudden rpm changes. If your engine is tuned perfectly to run 100 octane on a cool day it is likely it will detonate on a hot day. If your gear box maximizes torque then changes in fuel / air ratio could easily create a problem. Design for the unexpected. Leave yourself some room for variation. You will undoubtedly be surprised by the unexpected but perhaps you can still cross the finish line. Good luck
I understand. I'm thinking 100 may be the minimum octane at this point. Thank you for your insight. Most of the tracks here in the SE are within a 500 ft in elevation, but we start this time of year with temps in the 40's F and go to low 100's in the summer. I'll definitely keep a good eye on the AF as we start to warm up. I've found I'm fully capable of doing unexpected things to an engine
. Hopefully not real soon on this one.
82SC Track Car |
3 restos WIP = psycho
I assume your class rules won't let you run a knock system? If you can, this takes a lot of risk out of the equation. This is how the 3.6 cars runs such high compression with low overlap cams without detriment. As evidence, have you ever seen a 3.6 on carbs (not using the DME)? I have seen more than a few holed pistons when the owner didn't realize you can't run these motors without knock detection and expect them to live.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Like Henry wrote, more information is necessary to offer anything constructive. For me, any engine without knock-sensing at 11.3:1 used for the track needs 108-110 octane fuel, especially in hot weather. One can run 100, but with reduced timing and that simply adds to the heat load in the heads.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
...go efi and let it compensate. easier said than done, right? imho, staring at the afr gauge is dangerous and it'll probably be too late unless you just run rich.
82SC Track Car |
82SC Track Car |
82SC Track Car |
More important than static compression ratio is your dynamic compression ratio. You can run 11.3:1 on street fuel so long as your dynamic ratio is 8.6:1 and below ish. Race fuel is needed with ratios above that, but this is a good rough guideline. Your dynamic ratio is a calculation from your static ratio and when your intake valve closes thus creating your 'effective stroke'. This figure can be calculated if you tell me your rod length and at what point your intake valve closes ABDC @ .050 or whichever figure you have. A late closing intake valve lowers your effective stroke and raises peak bhp and torque to a higher rpm.
The motor is a short stroke 3.2 or a 3.0SC engine with 98mm pistons. I'll see if I can't get the cam information. Thanks
82SC Track Car |
Here are some more engine details:
The rods are stock 3.0SC length 127.8mm I think. The heads are stock 3.0SC that have been machined for twin plugs and mild porting of the intake/exhaust. Competion valve job. The basic shape is unchanged. The pistons are JE. I believe they are 11.5 machined to 11.3. The cams are built for the engine. Seat duration (at .012" lift) intake 316 Seat duration (at .012" lift) exhaust 307 .050 duration intake 278 .050 duration exhaust 267 Gross valve lift intake .525 Gross valve lift exhaust .514 Full intake lift 101 ATDC Full exhaust lift 103 BTDC I don't know if this information helps clarify my octane requirements. Thanks for your help.
82SC Track Car |
With that kind of intake lobe center and overall seat duration, your dynamic compression ratio will be very good for street fuel. Seat duration has your intake closing at 79 ABDC. Dynamic ratios are best calculated with the valve still open about .004, so 76 degrees is a safe figure to operate from for calculation effective stroke. I estimated what I didn't know (piston dome volume and deck height etc) to get to 11.3:1. I do not know your combustion quench or the specific efficiency of this engine, but I am calculating a dynamic ratio of 8.118. You should be in great shape. Power will be up there around 7400+. What a sound
No physical quantity completely explains its own existence |
Thank you for crunching the numbers. I'm looking forward to some good dyno work in a few weeks.
82SC Track Car |
