Less brakes, more gas!
euro911sc's Avatar
Question Which Main Bearing Set?
With regards to Main Bearings: is there a GOOD reason not to buy the Glyco main bearing set for ~$900 LESS than the OEM Porsche set???
As offered by our host here:
Main Engine Bearings
I mean, I'd like to support Pelican, but if there are other mid range alternatives then I'd like to hear them to make a good choice balancing quality and price.
Also, #8 doesn't come with... Is this a replace the O ring and go or just bite another $X00 on the old budget line?
Best regards,
Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 08-04-2006, 02:49 PM
not 100% sure, but glyco manufactures bearings for Porsche too.........
this are good products...
Old 08-04-2006, 03:13 PM
I've used the Glyco on 2 engines now with good result. I don't see a problem with them. I've been able to reuse my #8 bearing on the engines I've rebuilt.
-Andy
Old 08-04-2006, 05:20 PM
Super Moderator
cstreit's Avatar
I've used the Glyco bearings in many engines including a highly-stressed 9000 RPM 2 liter and my 3.3L race engine. Teardown showed nominal wear. I use them without concern.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 08-04-2006, 09:18 PM
Jeff Alton's Avatar
NO reason not to use them.
Cheers
www.turn3autosport.com
Old 08-05-2006, 09:50 PM
euro911sc's Avatar
Excellent!
-m
Michael
'13 Cayenne GTS
Old 08-07-2006, 08:35 AM
Carrerax's Avatar
Ok, sorry to open an old thread but Im wondering if people still feel the same after a few years.
1997 C4S stock...ish
1970 911T Restored Hot Rod....Sold
http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html
Old 04-06-2010, 03:14 PM
Ive used the Glyco for 30 years. Once its running and has a sheet of oil on it your bearing is supporting the oil, then the crank. What spec would change because of the embossed Porsche Number on it?
Bruce
Old 04-06-2010, 04:27 PM
Carrerax's Avatar
Thanks for the reply Bruce. What about the stories of having to sort through sets of them to get all correct size or good ones? Maybe that isnt this brand though.
Old 04-06-2010, 04:51 PM
For the money we pay for the mains, the supplier to the factory, if quality is an issue it could cost the reputation of the company.
Bruce
Old 04-07-2010, 04:17 AM
Walt Fricke's Avatar
Were I more adept at this, I'd post the reference to a more or less current discussion here about just this. The assertions were that quality control may have slipped. Factory GT3 bearings as substitutes or something? A search will find it easily. It started with a teardown of a fairly fresh engine, with bearings showing crosswise striations or washboarding (apparently, per the photos). A heavy hitter or two joined in with experience based opinions. The rest of us scratched our heads, wondering what this might meanfor us.
Me, I just send my not yet installed rod bearings to Calico after hearing that, for coating.
One engine builder of good repute likes undergrinding cranks so he can use Clevite bearings. Stronger steel backings? Less ovality? Can be purchased coated?
Hard to keep up with things - Carillo rods had some issues at one point? And they were the gold standard of hot rod engines short of factory titaniums.
Old 04-09-2010, 10:39 PM
Max Sluiter
Flieger's Avatar
Engine Bearings Questions
Old 04-10-2010, 12:42 AM
Carrerax's Avatar
Thanks Walt and Fleiger. I had watched that thread before. I am going to use GT3 Rod bearings but I am having a real hard time with the $500 (rough guess) diff between glyco and OE Porsche supplied. That said, $500 isnt much relative to the money I will have in my motor but it still is enough to warrant investigation. Does anyone have info on this "Calico" company or somewhere that does this coating? In the end, I will probably just get them all from Porsche. I think that I would stay up at night second guessing myself. That said, I buy all the parts possible from Wayne whenever possible.
Old 04-10-2010, 04:04 AM
Carrerax's Avatar
Ok, I found info on Calico if anyone is interested (no affiliation etc):
ceramic coatings, teflon coatings, thermal coatings solutions with Calico Coatings
Maybe this is the hot ticket to use if you buy the glycos?
Old 04-10-2010, 05:07 AM
Calico is great to deal with. Send your bearings, you get them back coated in under a week, plus or minus.
One wants to be careful here with tolerances, though. If you have a crank whose diameters are at the upper end of the tolerance (as if new, for instance), you'd want to be careful that coating your bearings wasn't going to make things too tight.
I think Calico would control coating thickness, if asked, but haven't asked. My cranks have all been well worn and at the lower end of the scale, so I haven't worried for my motor. A slightly smaller bearing ID is a plus for that.
The expensive coated bearings one can purchase off the shelf no doubt have had this taken into account so that the resultant is at "standard" to begin with.
These coatings aren't thick, but neither are they zero. Maybe they are close enough to zero as not to matter?
Old 04-10-2010, 01:07 PM
tadd's Avatar
Does anyone have some before and after pics of coated DFL bearing? I'm curious if it truly stays or if it is kinda sacrificial like the break in coatings for piston skirts.
t
Old 04-10-2010, 05:29 PM
