efhughes3's Avatar
Ruby's engine rebuild-Rev1
I rebuilt the engine a couple of years ago keeping the stock P's and C's as they were fine-and I needed to keep my budget at the number I had in mind at the time. No real expense other than that was spared to build a good solid 3.2. She runs great, and I've probably got 7 or 8000 miles on her in the 2 years since the build.
But I have a slight leak (bristle from the brush used to spread sealant?) between the head and cam tower at #3. I've not been motivated to fix this as I'll end up having to tear down the top end on the LH cylinder bank, and she is so much fun to drive!
Anyway, yesterday I decided to get to these new P's and C's for a bit more power, which will motivate me to move on this. Mahle 98's in 10.5:1 compression. I'll also go to twin plug via an Andial splitter setup-I'd machined the heads for the extra plugs when I built the motor. I'll probably look to start late in Feb or early March. I'm going to strip her down to the case-no need to split it-clean, inspect and assemble.
I'll document this as I go.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 01-09-2010, 07:39 AM
I would rather be driving
jpnovak's Avatar
Ed, You will have lots of valve clearance with those pockets... HInt hint, wink wink...
New cams?
Old 01-09-2010, 12:35 PM
efhughes3's Avatar
I hear 'ya! I did cams on the first go.....got the DC19 profile which has a bit more lift than a 964 grind from John @DRC. I really only need to think about doing some work on my intake manifold to help with the increased capacity.
Ed Hughes
2015 981 Cayman GTS
Old 01-09-2010, 12:43 PM
911 tweaks's Avatar
can't leave well enough alone here huh Ed... ;-) its just a minor oil leak, right...
I will follow your build as you do a great job writing up your journey...
Bob
I live for 911 tweaks...
Old 01-09-2010, 01:01 PM
Capitalist and Patriot
911Freak's Avatar
SUB'D
Looks like this should net some nice #'s!
Former Test driver & Production Manager Singer Vehicle Design
2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold)
"Dream it, Believe it, Decide it, DO it "
Old 01-12-2010, 03:22 PM
175K911's Avatar
Hey Ed, those are probably about the most expensive boxes to land in your garage aren't they? Have fun with the build. I just finished taking mine down to the case today and will split the case and pull the rods in a few weeks. Thank heavens for the winter season to pull off projects like this.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 01-12-2010, 04:42 PM
efhughes3's Avatar
They are very expensive. My rebuild was right at five figures, and this is going to be 3/4 of that again with the P's/C's, ignition, clutch, injector cleaning, etc.
Winter? That is the big dilemna! When do you take a perfectly good 911 offline in San Diego County?!?!
Good luck on your build.
Ed Hughes
2015 981 Cayman GTS
Old 01-12-2010, 05:10 PM
Jeff Alton's Avatar
Ya, I saw your pics of the new years day drive and commented to Dee and Wade that "we could live there"....
Cheers
www.turn3autosport.com
Old 01-12-2010, 05:32 PM
efhughes3's Avatar
Just to keep us honest down here-we've been in the 70's since the end of '09-the El Nino cycle may be starting next week, so it may be a wet spring.
Old 01-12-2010, 05:47 PM
175K911's Avatar
Go ahead, rub it in. If it wasn't for Chicago winters, I'd never find the time to do the projects. But it does mean working in an unheated garage when it's -6 out. Today it was 25 out and I got the garage temp up to 48, downright toasty.
You're going to have a really fun car when the engine's all done. You're building the engine I'd considered before going the 3.6 route. Will you dyno it when done?
Ed
Old 01-12-2010, 08:13 PM
efhughes3's Avatar
I hope to dyno it soon after with Mr. Wong present.
Old 01-12-2010, 08:42 PM
Boy... I envy you guys that have the courage and skill to do your own rebuilds. I know my limitations and engine work is not within them. I do enjoy the cosmetic side of things though.
Will enjoy your write-up Ed
Oh... I do change my own oil
O2 In Sully We Believe
Old 01-17-2010, 05:52 AM
efhughes3's Avatar
Courage and Ignorance!
Old 01-17-2010, 01:12 PM
dshepp806's Avatar
Fear & Loathing on the Porsche Trail ?
We'll keep the eye out for your progress, Ed.
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 01-21-2010, 06:00 PM
efhughes3's Avatar
Well, progress is that the jewels arrived at the house today :
Ed Hughes
2015 981 Cayman GTS
Old 01-21-2010, 06:12 PM
911 tweaks's Avatar
looks great Ed...whats up w/ the balck board pictured there...twin plug controller??
Also, thx for the travel info tips...I'll call you if you can pm me your #.
Bob
Old 01-21-2010, 06:43 PM
efhughes3's Avatar
Yep, that's a splitter for the DME to run the twin coils.
Ed Hughes
2015 981 Cayman GTS
Old 01-21-2010, 06:49 PM
TibetanT's Avatar
There you go again...having fun in a warmer climate. Ha.
Those are very nice P/C's you have acquired!
Good luck with the rebuild. Looking forward to all the pictures and progress.
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 01-22-2010, 08:32 PM
efhughes3's Avatar
It starts on 2/20:
San Diego area (Escondido) engine drop 2/20-Invitation
Ed Hughes
2015 981 Cayman GTS
Old 02-05-2010, 07:28 PM
Jeff Alton's Avatar
good luck, Ed, I am sure all will go well!
Wish I could be there...
Cheers
Old 02-05-2010, 09:49 PM
