Brando
quattrorunner's Avatar
No-8 o-ring seal.
So I did a great job of assembling my crankcase. Forgot the o-ring on the no 8 bearing. Awsome.
Old 11-18-2010, 10:25 PM
brads911sc's Avatar
wow. that sucks. i feel your pain. i am looking forward to making similar blunders. hopefully you can get it apart and fixed without having to buy more parts...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 11-19-2010, 04:33 AM
I did not forget my O-ring but mine would probably seal better if I did. I put it in with a light coat of oil and although it didn't leak in the beginning, it leaks like a sieve now. Tempted to just glue the joint but that just wouldn't be right.
Lindy
Old 11-19-2010, 06:11 AM
lindy that will not help been there done that . they do make a oversize o-ring also paint some light coating of permatex (non hardening) around bearing and o-ring groove . this has been a sore spot on these engines for a long time. good luck regards tom
Old 11-19-2010, 10:36 AM
