ONQRACIng's Avatar
2010 GT3 Crankshaft Part number
Looking for the part number for the 2010 GT3 Crankshaft. I know it runs $1800 from the dealer, but the parts department at the dealership near my home, the counter monkey has no clue..
TIA....
Old 12-27-2010, 02:29 AM
Bill Verburg's Avatar
Originally Posted by onqracing View Post
looking for the part number for the 2010 gt3 crankshaft. I know it runs $1800 from the dealer, but the parts department at the dealership near my home, the counter monkey has no clue..
Tia....
996.102.021.94
Bill Verburg
Old 12-27-2010, 12:32 PM
andrew15's Avatar
$1,623 from Pelican
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 12-28-2010, 07:59 PM
ONQRACIng's Avatar
Gt3
That is interesting Andrew15, the dealership is $1800, and I know there are two or three variants of GT3 shafts. We are in the process of a CMW stroke rebuild after snapping a CMW ground 3.0 shaft, and the realization that another grind is futile. We plan on a GT3 shaft and custom rods from Charlie at LN.. 132mm to be exact. With 100mm jugs.
Let me look into this PP pricing..
Thanks!
Old 12-29-2010, 03:59 AM
304065's Avatar
Thanks!
Hmm. . . that was a change up that just went by. . . to maintain the original geometry you would have to use a 62mm stroke to fit 132mm rods. . .unless you are moving the rod up in the piston. So that works out to 2,922 cc. But a GT3 crank is a 76.4mm stroke. So without moving the pin you end up with a motor that is 7.2mm too wide. Help me out here if I am missing something.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 12-29-2010, 05:52 AM
ONQRACIng's Avatar
Here is the original build of the CMW engine.
Euro SC case
CMW Grind on a stock 3.0 crank to 77.5
Custom Cunningham rods 130mm
Custom JE Pistons 100mm with Mahle Motorsports 100mm Cyls
So, since the crank snapped due to the over machining of the rod journals, which breaksout at the oil passages, we are going with a GT3 crank and 130.5mm rods to get us back to the deck we need. TurboKraft has done similar mods with a GT3 crank, so it should be ok..
Old 12-29-2010, 01:38 PM
txhokie4life's Avatar
I was just looking into sourcing one of the 2010 GT3 crankshafts
but there is none to be had -- even in Germany, back ordered indefinitely.
alternatives in the same performance/price range?
m
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo
2001 996 GT2
1999 Spec Boxster, 1996 993 Cabriolet
1992 964 Cabirolet, 1975 911 RSR Replica Race Car
Old 05-11-2011, 09:46 AM
R.I.P.
drmatera's Avatar
I know I'm digging up an old post but is this crank still available? I'm looking to run one in my 930 motor
Old 08-10-2011, 03:30 PM
Ken911's Avatar
I keep hearing they are back ordered so long that there is no date. turbo kraft got about the last one avaiable and they havent been able to get any more of them. I think henry schmidt was going to have another batch of his custom super tech cranks made up. If you did that you would still be able to use the set of rods you have.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 08-12-2011, 04:37 PM
gtc gtc is offline
abides.
gtc's Avatar
I don't know how/if it differs, but I recently saw this one on ebay.
Old 08-16-2011, 10:11 AM
Try not, Do or Do not
Henry Schmidt's Avatar
We generally have one or two in stock.
Email me for price.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 08-16-2011, 08:00 PM
