83 911 Production Cab #10
Engine plug?
Any idea what that is (look like a plug with a date code) and why its there(right side lower casing)?
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Is this on the engine case? should be one of these on each side of engine case, left and right side.
Is this a 3.0L or a 3.2L? If 3.2L engine, best guess...the 28th week of 1985 ...but I am no expert.
Ed Paquette 1983 911SC 1987 944S 1987 944 Manual (Donated to the Nat. Kidney Foundation) 1987 944 Automatic (Recently sold to another Pelican) |
I guess I could have supply more info... 86, 3.2 Engine, so the 28th week in 85 does make sense On the passenger side of the Crankcase (930 101 104 5R) Nothing on the other side (930 101 103 6R) What is (was) the purpose for it? Cheers JJ
Max Sluiter
The purpose is just to keep track of production. If something does not meet QC specs, they can identify when and what die the problem occurred, then go and fix it and then inspect the ones that were made after that more closely. It also is nice to know when the part was made, just like it is nice to know when your car was made, even if an 83 is basically the same as a 78 or an 85. Fatigue cracking, for one, though this only seen in highly stressed engines.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Max Sluiter
By the way, just to make sure you know, it is an imprint from the mold, not a "plug".
I called it a plug because it resemble to wooden plug I made for a Windsor chair.
I do QA check on 1st Level casting for submarine valve and the likes but we use a different marking systems. What trough me off is the "look" of the bar between the Year and the Week as it does not really match its surrounding and being paranoid about finding bad news ![]() ![]() ![]()
