Deadeye's Avatar
3.6 P's & C's and heads on a 3.2 case?
How difficult would this be?
Old 02-10-2011, 04:19 AM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
A lot more difficult than finding a 3.6 case...
Scott Kinder
kindersport @ gmail.com
Old 02-10-2011, 10:00 AM
I've seen it done. IIRC They set the case up and installed case savers moving them out the correct distance from center. They also had to make spacers under the cylinders.
Old 02-10-2011, 11:16 AM
YTNUKLR's Avatar
Of course you can do it. the question is "why re-invent the wheel?" sell the 3.2 case, buy 3.6 case will be less hassle and time.
BUT, if you want to do it, you need Alu cyl base plates for sealing, bore the case to the OD of the base of the 3.6 cylinders and drill/tap for new head stud spacing.
Of course, you will also need a 3.6 crank/rods or you will end up with a 3.5 (using a 3.2 crank).
Old 02-10-2011, 11:28 AM
Deadeye's Avatar
Nuff said-thanks
Old 02-10-2011, 12:33 PM
ALXinNZ's Avatar
Damm I was thinking I could do this!!
Great thread I guess I will have to sell the 3.6 barrels and pistons i just got. You just saved me a lot of time and money
Cheers!
Old 02-12-2011, 11:12 PM
