help with remove broken stud
can someone tell me the best way to remove this stud . i used wd-40 with pipe wrench , but not works . is any other way or do i need any speical tools ? sorry i m noob . thanx
Weld a nut to the broken stud. Lots of penatrating oil. Then try some heat lots of heat. Chances are it will still break but will be your best chance.
i just tried now , it see not work for me . any other way ?
If welding a nut didn't work, then drill it out. Ther is a jig you can buy that helps to center the drill so you don't damage the threads.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
u mean like snap on screw extractors tools ? thanx for reply
God no, that will probably only get you in more trouble.
Take a look at this: Does anyone sell a fixture for drilling broken exhaust studs
Free minder
Here is what I used on my headstuds. Also, for heat, go with the yellow gas can, not the blue one.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) |
in australia ,i think we dont have that tools .
Drill and retap it. I just did it with the engine still in the car laying on my back, with a hand drill, and no jig, and somehow it worked. So its not that bad. Cut the stud flush to the head, center punch it, drill a small pilot hole, drill out with your 8mm bit or whatever matched the tap, then tap it. Just make sure you drill straight! Good as new
BTW i tried that stud removal kit and it didnt work for me, just snapped my stud even more. |
I would first attempt removal by welding a nut to the remains of the stud and use a MAPP gas torch to heat the area of the head. Once nice and hot, I would use an impact gun to try to back out the stud.
If that didn't work, I would do as suggested and center punch the stud and drill it out in a drill press. You could always take it to a machine shop and have them fixture the head on a mill and let them drill and tap the hole. Best of luck to you.
John Flesburg 2016 981 Boxster S.................| 1983 911 Turbo - (White) 1974 911 3.2 - Red Car........... | 1974 914-6 3.2 - (Silver) 1974 914-6 3.2, GT -(Red).......| 1974 914 - 2.7 GT Clone (TBD - Saphire?) 1971 914 (TBD)..................... | |
The heat from the welding seams good to help break the corrosion.
another stupid question .
![]() how do i remove this part .
The cylinder? Pull it out.
I'm trying to be helpful and not a dick, but if you don't know it's the cylinders, maybe you should put the tools down and walk away. In any case you MUST buy Waynes book. It is very good and VERY cheap in the grand picture. Pelican Parts.com - How to Rebuild and Modify your Porsche 911 Engine You can also find it on Amazon and other intenet bookshops.
i just going to order one ^^ should be get by next week
it seen very very hard to pull out , not even moving, any trick . thanx
Try tapping it with a rubber mallet, be carefull not to break off any cooling fins.
ohho , after 15 minute , first one come out . thanx everyone
