djpateman's Avatar
Originally Posted by Grady Clay View Post
Can you post all the numbers from the crankcase?
What is the engine number (green arrow below)?
It may be in the range: 6114001 on.
Here is the type number and build number (red arrow above).
What is the engine type number? It may be 911/07.
What is the engine ‘build number’? It should be just below the type number.
What are the case-half mating numbers?
It is on top of the crankcase, at a center case bolt between the middle cylinders (#2 & #5).
Usually 2-3 digit matching numbers.
What are the two (different?) casting dates?
They are on the front (pulley) end of the case.
They are a circle with a 2-digit year (70 or 71) and a series of dots around the perimeter of the circle.
What are the two casting numbers on the lower sides of the crankcase.
You can’t miss them.
911.101.101.2R 911.101.102.3R or something similar.
Notes: only 911 2.0 engines got the build #, it was discontinued in 1970 MY
The aluminum case engines from 1965 to 1968 had the casting date on the pulley end of the case with a ring of dots around the year to indicate the month. I believe that the magnesium cases had a week/year code somewhere on the side of the case, but often it is hard to find.
The casting numbers should start with 901 not 911 IIRC.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 03-21-2011, 08:59 AM
Few photo's of numbers
I plan to spend the next two evenings turning my garage into a workshop -
Old 03-21-2011, 12:21 PM
Grady Clay's Avatar
Great pictures.
Can you find the casting dates on the crankcase halves?
Can you slip the case back together loosely and get an image of the two matching (parting) numbers (645) together?
(Keep the crankcase halves together to prevent damage. Bolt them together to spec for shipment.)
What are the numbers (S/N?) on your Zenith carburetors?
Another of possible is the crankshaft numbers and connecting rod parting numbers.
I’ll put together a collage of your images to show all the numbers in one [img].
Dave,
It will be good if we eventually have a thread on ‘How To Identify’ – engines, transmissions, 911s.
We need more good data-points and images like this.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 03-21-2011, 01:06 PM
I will take more pictures and post them ASAP.
All 6 rods are marked 911 103 103 OR (s) , and 33 31033 R on the flipside. I weighed them ( with bearings , bolts and nuts ). 2 X 773g , 2 X 774g , and 2 X 775g.
Camshafts 901-105-133 OR and 901-105-134 OR.
Old 03-21-2011, 04:07 PM
One Zenith still with my friend who service it.
Old 03-21-2011, 05:09 PM
djpateman's Avatar
Thread on 2.0 engine build #'s
Type 901/xx Engine Build #'s
Thread on engine case #'s
911 engine case Revisions
Yeah, I know they are not on Pelican, but I can update the first post any time, instead of being restricted to a few months.
Addicted since 1975
Old 03-21-2011, 05:12 PM
Old 03-21-2011, 05:44 PM
912 Roller
Old 03-21-2011, 09:33 PM
Old 03-21-2011, 09:38 PM
Old 03-21-2011, 09:41 PM
Old 03-21-2011, 09:47 PM
I spent some time making space in my garage to work , sit , think , etc.
This was after numerous threats from the homefront about using the living room , kitchen , and ( yes ) dishwasher.
Following advice from members I baged and marked parts in ziplock bags , and then put them in marked boxes.
Old 03-22-2011, 07:39 PM
I have been told that a rookie mistake in a setup like this is not including a girlie calender and dartboard.
Old 03-22-2011, 07:45 PM
304065's Avatar
For best results I recommend Gil Elvgren.
But seriously, I would get yourself a can of LPS-4 rust inhibitor- basically spray on cosmoline, and dowse those rods and cams before they sit. Even in the dry AZ desert (I grew up in Tempe) those newly exposed, run-in surfaces are prone to rusting.
Other than that I say, Looks Great, carry on!
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 03-23-2011, 04:04 AM
This is what I read everyday -
Old 03-23-2011, 07:30 PM
ratpiper71T's Avatar
Wink
It is imperative that anybody rebuilding a Porsche engine stay focused , do the research on every step , and then proceed in an exact manner.
If you have confidence in what you are doing , there are no limitations.
Okay man, gotta ask...what ..err.. Where is the hand?!?!?!
Wait are you grabbing a lion by the cahones?
Now, that's confidence! Well it's a lot of other things too, but that's definitely confidence, there!
Old 03-29-2011, 10:12 PM
Ratpiper -
The photo was e-mailed to me by a friend in Africa , I am not the one advancing the dizzy on this beautiful specimen.
I was born , and lived in Africa for 40 years.
Old 03-30-2011, 07:02 AM
Max Sluiter
Flieger's Avatar
I couldn't resist.
Caption this photo!
Old 03-30-2011, 10:19 AM
I received the micrometer yesterday , stored it overnight next to the crankshaft under controlled conditions , and calibrated it this morning. I took a zillion measurements this morning to make sure I get it correct. Grady said it takes practise.
Old 04-03-2011, 09:15 AM
D1 and D2 on all measures between 56.982 and 56.984. In the middle of the spectrum. Very good news indeed !
Old 04-03-2011, 09:29 AM
