Todd - as all the nuts show the same thread , it is not a single bolt defect. I have used an endoscope to look at the back of the bolts. They are all seated perfect and did not overturn.
In that case I received the wrong bolts. These must be 2.0 bolts in 2.2 rods.
I bought these from a reputable dealer , and as we do not live in a perfect world , I will get new ones from another source.
Old 08-18-2011, 05:31 PM
Rookie mistake # many
I can not believe I missed something like this .
Old 08-18-2011, 06:11 PM
Case apart again - cleaning Loctite off casehalves must be the top rated hobby on this forum.
New bolts suppose to arrive tomorrow.
This time I will use my micrometer to make sure I receive what I paid for.
Old 08-21-2011, 03:28 PM
New rod bolts
New rod bolts received and installed - torqued to 39 Ft-Lb using oil as lubricant to overcome friction.
I will use Curil-T , Loctite 574 , Loctite 518 , and black RTV sealant to seal the case. That will cause 50% of Pelicans to agree with me. If I chose different sealants , 50% of Pelicans would have agreed.
Old 08-23-2011, 05:37 PM
New ( incorrect ) bolt , and new ( correct ) bolt.
I wonder if using red loctite would have worked on the shorter bolts ? Given the hours I have spend on this , I will not take a chance.
Old 08-23-2011, 05:47 PM
Eschews Obfuscation
dhagood's Avatar
Originally Posted by 356RS View Post
Errie, Great thread on your engine assembly. One thing I see odd is the lack of threads showing on the connecting rod bolt after your torque down. That might be just the camera angle but you stated that it was just before case half's going together.
nice catch!
'84 Porsche 911 Targa
'97 Ford F250 Heavy Duty
'98 Volvo S70
'02 Subaru Forester
'05 VW Passat TDI
Old 08-23-2011, 06:23 PM
Threebond 1194 and 1104 ordered - will follow Henry's advice.
Hope to mate the case halves end of next week. That is the curse of living in an area where everthing needs to be ordered.
Old 08-25-2011, 03:52 PM
350HP930's Avatar
I'm glad to see you caught this ahead of time, but you could have swapped the rods in and out of the case without disassembling it. There's a reason why they put the rod bolt nuts on the piston side after all.
Old 08-25-2011, 05:10 PM
I was considering that , but because I missed something so obvious I wanted to make sure everything else is ok.
Still wonder if red loctite would have worked.
Any replies on the torque I used ?
Old 08-25-2011, 05:21 PM
350HP930's Avatar
If all the threads were engaged you might have been able to get away with the mistake.
Locktite isn't highly recommended for rod bolts though.
Old 08-25-2011, 06:00 PM
Change in gameplan
Henry - following your advice. The curse of living in an area where everything needs to be ordered and takes time , received the 1194 today.
Hope to seal the halves , and do some more, in the next week.
Old 09-01-2011, 05:33 PM
As this is a magnesium case , even though an alloy , Threebond 1194 would be the case sealant of choice. Casework was done by Ollie's , and I hope to be close to perfect.
I am willing to bet my left ( or both my brothers's ) , that this build will not have an oil leak.
Old 09-01-2011, 05:42 PM
My son Stephan came to visit and gave me the extra pair of hands I needed to seal the case. Used Threebond 1194 , Loctite 574 and Curil T .
I used an acid brush to apply the sealants as evenly as possible , and was able to mate and torque everything in 23 minutes.
Old 09-03-2011, 05:55 PM
Old 09-03-2011, 06:00 PM
JE pistons and cylinders - same crank and rods - diameter increase of 2 mm.
Old 09-03-2011, 06:10 PM
Torqued through bolts without o-rings , torqued perimeter nuts , waited 5 hours , and added o-rings to through bolts one at a time and torqued to spec.
Old 09-03-2011, 06:31 PM
Got a lot done yesterday -
Old 09-04-2011, 08:40 AM
Pistons and cylinders installed using a 1mm copper base gasket supplied by machine shop - based on work done on cases and heads.
Clips no problem at all - used a $2 tool from ACE. Not one flyer .
Heads dry run - ordered new head nuts.
Re-ordered flywheel bolts - received the incorrect ones a few months ago , and only realized that when opening them.
Old 09-04-2011, 10:03 AM
Modified air baffles.
Old 09-04-2011, 10:13 AM
I need 4 head washers , n/a from our host. As the others are perfect , it would be a waste to buy a whole set. Any suggestions ? Are there washers with the same specs and standards available at an auto shop ?
Old 09-04-2011, 10:29 AM
