"O Gruppe 13"
IDGAF27's Avatar
Send a message via Skype™ to IDGAF27
Engine Dyno in North NJ ?
Looking forward to dyno test my new engine for project in progress.
Any leads where I could put it on stand and test ? Want to see numbers. Will it be enough to pull my 67 911 SWB
Quick info on motor - 3.0l made into 3.2L , Mahle C&P's, Port&Polished, Twin Plugs ( not hooked yet, waiting for distributor), Weber's 46's tuned down for S cams etc.
G-Man
89 964 C4
86 930
Old 03-10-2011, 01:42 PM
E Sully's Avatar
It's a little bit of a drive, but if you want to hop over the border into Rockland County, DeMan Motorsports has an excellent dyno. His # is 845 727-3070.
Ed
1973.5 T
Old 03-10-2011, 01:55 PM
"O Gruppe 13"
IDGAF27's Avatar
Thanks and awesom.
I know DeMan. Have been there few times. Never bothered to ask them about dyno stand. dah!
G-Man
89 964 C4
86 930
Old 03-10-2011, 02:00 PM
Navin Johnson
TimT's Avatar
I think Peter Dawe has an engine dyno. Pretty sure Rick only has a chassis dyno
'69 911 GT-5
'75 914 GT-3
and others
Old 03-10-2011, 02:27 PM
Grady Clay's Avatar
IDGAF27,
Do you want an engine dyno or a chassis dyno?
There is a significant difference.
I’ll encourage you to find an engine dyno.
Every top professional engine builder has an engine dyno.
This is much more accurate for measuring but that isn’t normally the issue.
A well set-up engine dyno with the ability to control the air and oil temperatures and have absolutely no exhaust reversion is what you are looking for.
This will allow you to ‘run-in’ your new engine under very controlled conditions.
While you want to run it under varying loads, you want to temperature cycle it quite a number of times.
You want to confirm your new distributor is operating correctly (you can watch with a timing light).
You want to be able to finesse the carb settings and jetting (have calibrated exhaust measuring equipment and spare carb jets).
After some run-in, you want to re-torque the rocker arm shafts and cylinder head nuts (bring your calibrated torque wrenches).
You want to adjust the valves and confirm the cam timing (bring the valve and cam tools).
You can do several oil changes and inspect the filter and sump for anything.
Of course, there will not be any oil leaks to find (bring a drip pan just in case).
All of this is very easy on an engine dyno.
… and you can listen – up close with a stethacope.
When everything is done, you can install the engine in your car, knowing it will run perfectly from the first crank of the starter.
Knowing your torque, horsepower and mixture as a function of rpm is a valuable extra.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 03-10-2011, 02:48 PM
"O Gruppe 13"
IDGAF27's Avatar
Grady, thanks . You are correct, I am in need of ENGINE Dyno stand . My intentions are to make sure engine set up right and I am aware how to redialed based on Cams are in.
G-Man
89 964 C4
86 930
Old 03-10-2011, 05:55 PM
"O Gruppe 13"
IDGAF27's Avatar
You have his #?
G-Man
89 964 C4
86 930
Old 03-10-2011, 05:57 PM
ONQRACIng's Avatar
Give Mike Bavarro a call Bodymotion in NJ..
Old 03-12-2011, 03:41 AM
"O Gruppe 13"
IDGAF27's Avatar
Bodymotion is bit on far side from me.
DeMan has chassy dyno. Not what I am looking.
Still searching.
G-Man
89 964 C4
86 930
Old 03-13-2011, 12:44 PM
Navin Johnson
TimT's Avatar
Home - Dawe's Motorsports
I know Pete has a test stand.. not sure if it is a dyno..
Since it really doesn't take to long we will stuff an engine in a roller and use our chassis dyno..
'69 911 GT-5
'75 914 GT-3
and others
Old 03-13-2011, 06:38 PM
304065's Avatar
Gytis, Peter Dawe has THREE dynos. Call him. about $600 per day for tuning I think.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 03-14-2011, 10:22 AM
