-   -   The Beautiful Puzzle: 1987 3.3L 930 EFI Build (http://forums.pelicanparts.com/911-engine-rebuilding-forum/598040-beautiful-puzzle-1987-3-3l-930-efi-build.html)
E-man930 08-25-2011 04:54 PM
Very nice transmission pr0n!
Are you going to slap on a billet sideplate while you are at it?
I may be interested in having my box gone through in the spring so I'll PM you for details...
E-man
CaptainCalf 08-25-2011 04:57 PM
Thanks E-man!
Yep, billet cost $200 extra, but while ur in there;)
E-man930 08-25-2011 05:38 PM
I meant the diff cover / side plate, not the bearing retainer - which is a great upgrade on it's own.
CaptainCalf 08-25-2011 05:49 PM
Oh, no gotta draw the line somewhere...now where did that line go?:)
350HP930 08-25-2011 05:57 PM
LOL, the 'while you're in there' addiction can be very strong.
CaptainCalf 08-27-2011 11:50 AM
No doubt, I've got it so bad I'm shaking just thinking about the EFI:)
CaptainCalf 08-27-2011 12:00 PM
Exh gasket choice
Which exh gaskets should I use?
http://forums.pelicanparts.com/uploa...1314471641.jpg
JFairman 08-27-2011 12:05 PM
The ones on the left!
CaptainCalf 08-27-2011 12:11 PM
Tranmission, sprockets, headers all done!
Headers done thanks Brian!
Tranmission done thanks Mike!
Sprockets torqued but what should the parallelism measurements be on a 1987 930 case?
I've got these measurements that don't match Bentley and I can't decifer what Wayne's book says...3 shims on the left and 4 shims on right:
8mm = intermediate shaft
Edit: Correction not 57mm...actually 53mm = right sprocket
107mm = left sprocket
Edit:Would it work best if I took the 4 shims on the right off and the 3 shims on the left off???
http://forums.pelicanparts.com/uploa...1314472077.jpg
http://forums.pelicanparts.com/uploa...1314472122.jpg
http://forums.pelicanparts.com/uploa...1314472157.jpg
http://forums.pelicanparts.com/uploa...1314472191.jpg
CaptainCalf 08-27-2011 01:05 PM
Will do and thanks!
350HP930 08-28-2011 01:28 PM
Are those mounting points next to the wastegate outlets or are those O2 sensor bungs?
CaptainCalf 08-28-2011 03:51 PM
Lambda bungs with plugs cuz I wont be using them to start with...my Lambda will be pulled after the turbo before the mufflerSmileWavy
CaptainCalf 08-28-2011 04:13 PM
More progress today!
I was amazed at the amount of oil in these big brake lines that run from the oil tank area to the front right wheel area:eek:
http://forums.pelicanparts.com/uploa...1314573123.jpg
CaptainCalf 08-28-2011 04:32 PM
Oil line juction
What the heck is this intersection for???
http://forums.pelicanparts.com/uploa...1314574358.jpg
CaptainCalf 08-28-2011 04:52 PM
Turbo oil pump
Anybody know where I can source a new drive pin for my turbo oil pump? I'll also need a new seal to do this rebuild right...ThanksSmileWavy
http://forums.pelicanparts.com/uploa...1314575367.jpg
http://forums.pelicanparts.com/uploa...1314575390.jpg
http://forums.pelicanparts.com/uploa...1314575470.jpg
http://forums.pelicanparts.com/uploa...1314575507.jpg
CaptainCalf 08-28-2011 04:58 PM
oil tank out for cleaning
can a radiator shop clean an oil tank?
http://forums.pelicanparts.com/uploa...1314575883.jpg
http://forums.pelicanparts.com/uploa...1314575908.jpg
j911brick 08-28-2011 08:44 PM
Thermostat an bypass valve for front oil cooler.
350HP930 08-29-2011 10:55 PM
If you have a hard time sourcing the pin just give me the dimensions and I'll whittle you one, lol. ;)
CaptainCalf 08-30-2011 05:05 AM
Thanks, but I found them at McMasters...they have just about anything you could think of, but you have to buy 10:)
CaptainCalf 08-31-2011 06:49 PM
turbo oil pump dowel pins
If anybody needs a dowel pin to rebuild their scavange/turbo oil pump shoot me a PM and I'll hook you up. Warning these pins require a press to remove and replace...I can't even begin to tell you how much I like my 10 ton press:D
Oh yeah, got a new keg yesterday...Bells Two Hearted Ale and it rocks!!!
http://forums.pelicanparts.com/uploa...1314841763.jpg
