crank sensor tin mod sorted
Since the 930 didn't have a crank position sensor I had to mod the tin for the plug to run up topside
http://forums.pelicanparts.com/uploa...1322102035.jpg http://forums.pelicanparts.com/uploa...1322102043.jpg |
Switched gears today and worked on interior
Look what I found under the driver's seat. I wont be needing the CIS controller, but I think one or both relays will be needed. Isn't the black one a fuel pump relay?
http://forums.pelicanparts.com/uploa...1322168895.jpg |
Electric sport seats
these bad boys are heavy! anybody know a good lightweight alternative?
http://forums.pelicanparts.com/uploa...1322169007.jpg |
ready for a new carpet kit
old carpets are out...door panels next:rolleyes:
http://forums.pelicanparts.com/uploa...1322169166.jpg |
You can remove all the stuff under the driver seat and their harness since you're going EFI.
If you want you can now remove the upper and lower heavy stock rear sound pads and replace them with newer lighter weight material and the car will loose around 25+ lbs without getting louder inside. Then you can probably sell the stock rear soundpads to someone wanting those. The stuff on the floor pan weighs around 8 lbs and there's lighter stuff you can brush on there instead. |
http://forums.pelicanparts.com/uploa...1322209207.jpg |
Thanks Roland, those are sweet!
more progress
While I'm waiting for more engine parts I continued working on the interior and ripped out the old heavy oem rear sound pads & headliner...glass had to come out first.
http://forums.pelicanparts.com/uploa...1322534396.jpg http://forums.pelicanparts.com/uploa...1322534418.jpg http://forums.pelicanparts.com/uploa...1322534438.jpg If I go back with a RS style carpet kit deleting the rear seats will I have to cut out the rear seat mounting bracket that is welded in place in the middle of the two rear seats? |
I got some brass Ts and vac line in, so I plumbed the fuel pressure regulators. Is this vac port on the very bottom of the base of the C2 throttle body normally used for this?
http://forums.pelicanparts.com/uploa...1322619564.jpg http://forums.pelicanparts.com/uploa...1322619587.jpg |
Driver door lock stuck
The passenger door lock knob rotates the lock with ease open and closed, but the driver side seems to be stuck.
Could this key hole in the door jamb be the culprit? The ignition key doesn't fit it:confused: http://forums.pelicanparts.com/uploa...1322620099.jpg |
Sunroof is out
Pulled the sunroof in order to install the headliner and found lots of parts that need replacing. Mostly plastic bits, velvet & rubber seals & foam. Not sure how effective the foam was, but I plan to upgrade it with something that has better noise dampening properties.
http://forums.pelicanparts.com/uploa...1322620541.jpg http://forums.pelicanparts.com/uploa...1322620573.jpg |
Sunroof Headliner Pan & glass
The sunroof headliner pan needs a good cleaning & don't tell the wifie I have the front and rear glass in the guest bedroom:)
http://forums.pelicanparts.com/uploa...1322620912.jpg http://forums.pelicanparts.com/uploa...1322620945.jpg |
The keyhole on the door arms the factory alarm. When it was armed you would open the door normally with the key and then use the keyhole inside to disarm it. I think you had to do it without opening the door completely. I'm afraid to play with mine. |
alarm
Thanks WilltelSmileWavy
Damn Rick, I haven't seen the thread for a while since for some reason I didn't get an update notice. You've been hard at work since the last time I checked in on ya. ;)
New Headliner & Amazoned CR Fuel line
The new headliner is in and I got Amazon to upgrade the C2 fuel lines to stainless and teflon.
http://forums.pelicanparts.com/uploa...1322834528.jpg http://forums.pelicanparts.com/uploa...1322834544.jpg http://forums.pelicanparts.com/uploa...1322834556.jpg |
I'm assuming even with the windows and everything else pulled out there is no rust to be found? Porsche did do a awesome job coating those cars in order to back up their decade long rust warranty on them.
Now that I think about it I might still have the alarm key around here somewhere. I'll check to see if I can find it for you when I have a chance. |
If you have the alarm key that would be worth a 6-pack of good craft beer when I stop by to pick it up;) |
| All times are GMT -8. The time now is 08:24 PM. |
