Damn Rick, looking good. Guess its a good thing I took all the stuff out of the whale tail already for you. My guess is that you will be remaining rear wiper-less from this point on, lol.
I guess I'll have to stop once in a while and clean the ice off the rear window due to the endothermic reaction of the air sweeping by so fast:p |
Fuel pumps testing
Can anybody tell me the best way to run the 2 fuel pumps while the motor is out?
I'd like to flush the lines and test the pumps before I stuff the motor in there. I've already cleaned out the tank and put fresh fuel in it. Thanks, RC |
Turbo oil return line plumbed
I used Earl's -6an SS line from drip tank to the scavenge pump and the oem line over the tranny and added an inline 75 micron filter before the tank to catch any coke that may be created by the turbo.
http://forums.pelicanparts.com/uploa...1320972962.jpg http://forums.pelicanparts.com/uploa...1320973099.jpg http://forums.pelicanparts.com/uploa...1320973212.jpg http://forums.pelicanparts.com/uploa...1320973238.jpg |
Is that where you plan to keep the filter mounted? I ask, because I am fairly certain there is not enough room between the engine tin and the chasis/mounting rail for the engine rubber surround for this to work (did something similar on the other side and found out when installing the engine) . . .
BTW, I really enjoy following your build! |
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/636542-rebuilding-turbo-oil-scavenge-pump.html#post6332684 What is with all the hose clamps on the AN fittings? Trying to re-use some of the old hoses? |
Lol, clamps are like insurance you pay and pay but never really know if you have too much:)
Air Filter
Does this air filter look big enough? LOL:D
http://forums.pelicanparts.com/uploa...1321130808.jpg |
Been reading thread again and I'm interested to know a few details about checking valve to piston clears.
Can you describe how this is done...or a picture if you took one at the time. thanks [QUOTE=CaptainCalf;6263391]checked valve to piston clears tonight & bolted 964 Flywheel & sensor on...int valve min clears 1.5mm and 2.0mm for exh all good;) http://forums.pelicanparts.com/uploa...1316481102.jpg |
I turned it over by hand slowly while sneaking up on the clears. IIRC the adjustment screws are M6x1.0mm, so a complete 360 degree revolution is equivalent to 1mm. Hope this helps! RC |
V to P
There is a safer way to do this, set valve lash to zero or there about, for the intake valve on the overlap stop at 10 deg ATDC, slowly turn the valve adjuster in (each turn is 1mm) until you feel the valve touch the piston that is P to V for intake, back it out more than you turned it in for safety, the exhaust side at overlap stop at 7 deg BTDC and do the same thing, rule of thumb is minimum P to V on intake is 1 mm, exhaust minimum 2 +mm, the degree wheel settings may vary a little from cam to cam but that has been very close across the board
Mike Bruns JBRacing.com |
Thanks for the details.
Yes Mike's sounds like an easier one man operation. need to consider specs on specific cams but with care it sounds like a reasonably doable procedure. Quote:
throttle body linkage sorted
Decided to go with a 3.2 throttle body and linkage arm mounted to a 930 throttle plate that I reconfigured. Also, cleaned the heat shield so it's ready for some high temp paint and trimmed and primed a custom fiberglass GT3 rear valance.
http://forums.pelicanparts.com/uploa...1321498641.jpg http://forums.pelicanparts.com/uploa...1321498718.jpg http://forums.pelicanparts.com/uploa...1321498737.jpg |
Man that is ugly. Just kidding!!! Very, very impressive work. The only downside is that the air filter is going to make it hard to change spark plugs :)
That's a deal. As long as you let me stretch her legs a bit.
We'll just have to borrow my neighbors tool kit for the spark plug tool to do yours too (I have so many tools but nothing fits like the toolkit tool and I lost all my toolkits when we moved) :) |
| All times are GMT -8. The time now is 02:32 PM. |
