-   -   The Beautiful Puzzle: 1987 3.3L 930 EFI Build (http://forums.pelicanparts.com/911-engine-rebuilding-forum/598040-beautiful-puzzle-1987-3-3l-930-efi-build.html)
CaptainCalf 11-17-2011 05:53 AM
Originally Posted by DSPTurtle (Post 6376101)
That's a deal. As long as you let me stretch her legs a bit.
We'll just have to borrow my neighbors tool kit for the spark plug tool to do yours too (I have so many tools but nothing fits like the toolkit tool and I lost all my toolkits when we moved) :)
Fair enough, I have a flexible craftsman socket that works like a charmSmileWavy
CaptainCalf 11-18-2011 10:46 AM
valance base coat painted
Surprisingly the red looks like a pretty good match!
http://forums.pelicanparts.com/uploa...1321642001.jpg
x98boardwell 11-18-2011 12:12 PM
Wow!!!
Just noticed this entire thread... haven't been on the engine rebuilding forum for quite some time until my recent acquisition... nice work. beautifully done. Now, I will follow until you get her running.
Cheers,
Bryan
CaptainCalf 11-18-2011 12:45 PM
Thanks Bryan, good to have you on board!
RC
CaptainCalf 11-20-2011 03:56 PM
heat sheild & GT3 valance
painted the heat shield then had to cut it for the GT3 tailpipe...shouldda did that the other way around:rolleyes:
clear coat turned out so good on the fiberglass valance I didn't have to buff it at all:D
http://forums.pelicanparts.com/uploa...1321833208.jpg
http://forums.pelicanparts.com/uploa...1321833232.jpg
http://forums.pelicanparts.com/uploa...1321833262.jpg
5.7 GT1 11-20-2011 09:24 PM
The GT3 style exhaust looks awesome!
CaptainCalf 11-21-2011 05:25 AM
Thanks 5.7GT1SmileWavy
CaptainCalf 11-22-2011 08:06 PM
C2 idle valve orientation
should the arrow point up or down?
http://forums.pelicanparts.com/uploa...1322021189.jpg
WERK I 11-22-2011 08:13 PM
The arrow indicates the direction of air flow.
Beautiful work,btw.
WERK I 11-22-2011 08:16 PM
In other words, pointing towards the intake plenum.
CaptainCalf 11-22-2011 08:18 PM
vacuum port on C2 throttle body
is this port on the back of a C2 throttle body okay for the vacuum signal for the blow off valve?
http://forums.pelicanparts.com/uploa...1322021874.jpg
WERK I 11-22-2011 08:23 PM
Is that port above or below the butterfly? You'd want a port below the butterfly for vacuum when the butterfly closes under boost conditions,
CaptainCalf 11-22-2011 08:27 PM
IC Plumbing mostly sorted
more pics
http://forums.pelicanparts.com/uploa...1322022206.jpg
http://forums.pelicanparts.com/uploa...1322022387.jpg
http://forums.pelicanparts.com/uploa...1322022418.jpg
http://forums.pelicanparts.com/uploa...1322022443.jpg
CaptainCalf 11-22-2011 08:30 PM
yep, it's right on the base below the butterfly so it should be good to go...thanksSmileWavy
CaptainCalf 11-22-2011 08:32 PM
Beautiful work,btw.
thanks...it's finally coming all together:D
CaptainCalf 11-22-2011 08:35 PM
coils mounting location
this looks like a great place to mount the coils!
http://forums.pelicanparts.com/uploa...1322022892.jpg
turbo nut 11-22-2011 10:28 PM
I have mounted the coils there on a plate worked out great. I also was using Ford EDIS modules and mounted them to the back side of the intercooler.
CaptainCalf 11-23-2011 06:24 AM
Thanks Turbo Nut, you got any pics laying around?
RC
Ronnie's.930 11-23-2011 08:17 AM
Not that you are asking for suggestions, but if you replace the front intercooler mounts with rods and heim joints, like in the linked pic, it would clean up the look considerably . . .
http://forums.pelicanparts.com/4784249-post272.html
CaptainCalf 11-23-2011 08:22 AM
yep, that looks nice & thanks!
