LinkBack Thread Tools Rating: Thread Rating: 5 votes, 4.20 average.
350HP930's Avatar
Damn Rick, looking good. Guess its a good thing I took all the stuff out of the whale tail already for you. My guess is that you will be remaining rear wiper-less from this point on, lol.
Old 11-09-2011, 11:47 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #441 (permalink)
CaptainCalf's Avatar
Thanks Tony
I guess I'll have to stop once in a while and clean the ice off the rear window due to the endothermic reaction of the air sweeping by so fast
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD
1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD
2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha
Old 11-09-2011, 11:51 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #442 (permalink)
Fuel pumps testing
Can anybody tell me the best way to run the 2 fuel pumps while the motor is out?
I'd like to flush the lines and test the pumps before I stuff the motor in there. I've already cleaned out the tank and put fresh fuel in it.
Thanks,
RC
Old 11-10-2011, 11:12 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #443 (permalink)
Turbo oil return line plumbed
I used Earl's -6an SS line from drip tank to the scavenge pump and the oem line over the tranny and added an inline 75 micron filter before the tank to catch any coke that may be created by the turbo.
Old 11-10-2011, 05:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #444 (permalink)
Banned
Is that where you plan to keep the filter mounted? I ask, because I am fairly certain there is not enough room between the engine tin and the chasis/mounting rail for the engine rubber surround for this to work (did something similar on the other side and found out when installing the engine) . . .
BTW, I really enjoy following your build!
Old 11-10-2011, 06:56 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #445 (permalink)
Yes, I like it there but will move it if I have to. Thanks for the heads-up and kind words
Old 11-11-2011, 03:44 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #446 (permalink)
That will certainly be tight once the engine goes in. JFairman has something similar on his.
Rebuilding turbo oil scavenge pump
What is with all the hose clamps on the AN fittings? Trying to re-use some of the old hoses?
1987 GP White 930
1977 Ford Bronco
Old 11-11-2011, 11:38 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #447 (permalink)
Lol, clamps are like insurance you pay and pay but never really know if you have too much
Quote de CaptainCalf
Old 11-11-2011, 11:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #448 (permalink)
Air Filter
Does this air filter look big enough? LOL
Old 11-12-2011, 12:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #449 (permalink)
350HP930's Avatar
Concidering that there will be no room left in the engine compartment after its installed, my answer would be yes, lol.
Old 11-14-2011, 08:08 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #450 (permalink)
Hehehe, as long as there's room for the motor I should be good
Old 11-14-2011, 08:25 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #451 (permalink)
EmptyGarage's Avatar
Been reading thread again and I'm interested to know a few details about checking valve to piston clears.
Can you describe how this is done...or a picture if you took one at the time.
thanks
[QUOTE=CaptainCalf;6263391]checked valve to piston clears tonight & bolted 964 Flywheel & sensor on...int valve min clears 1.5mm and 2.0mm for exh all good
1986 930 EFI, twin plug, lovin the sport seats
Old 11-15-2011, 11:11 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #452 (permalink)
thanks
Sure, all you need to do to check the valve to piston clears is to run the valve adjustment screw to the desired clearance a little at a time while rotating the crank to make sure you don't get any collisions between the valves and pistons. Beware you could bend a valve or damage a piston if you turn the motor over to fast/hard
I turned it over by hand slowly while sneaking up on the clears. IIRC the adjustment screws are M6x1.0mm, so a complete 360 degree revolution is equivalent to 1mm.
Hope this helps!
RC
Old 11-15-2011, 11:21 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #453 (permalink)
V to P
There is a safer way to do this, set valve lash to zero or there about, for the intake valve on the overlap stop at 10 deg ATDC, slowly turn the valve adjuster in (each turn is 1mm) until you feel the valve touch the piston that is P to V for intake, back it out more than you turned it in for safety, the exhaust side at overlap stop at 7 deg BTDC and do the same thing, rule of thumb is minimum P to V on intake is 1 mm, exhaust minimum 2 +mm, the degree wheel settings may vary a little from cam to cam but that has been very close across the board
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 11-15-2011, 11:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #454 (permalink)
+1, go with Mike's procedure cuz I was really worried I'd get a collision and just plain lucky I didn't!
Old 11-15-2011, 11:47 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #455 (permalink)
Thanks for the details.
Yes Mike's sounds like an easier one man operation. need to consider specs on specific cams but with care it sounds like a reasonably doable procedure.
Old 11-15-2011, 12:03 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #456 (permalink)
throttle body linkage sorted
Decided to go with a 3.2 throttle body and linkage arm mounted to a 930 throttle plate that I reconfigured. Also, cleaned the heat shield so it's ready for some high temp paint and trimmed and primed a custom fiberglass GT3 rear valance.
Old 11-16-2011, 07:00 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #457 (permalink)
DSPTurtle's Avatar
Man that is ugly. Just kidding!!! Very, very impressive work. The only downside is that the air filter is going to make it hard to change spark plugs
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 11-16-2011, 07:23 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #458 (permalink)
Thanks Jason, I'll bring it over to your garage for help changing the plugs
Old 11-17-2011, 05:19 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #459 (permalink)
DSPTurtle's Avatar
That's a deal. As long as you let me stretch her legs a bit.
We'll just have to borrow my neighbors tool kit for the spark plug tool to do yours too (I have so many tools but nothing fits like the toolkit tool and I lost all my toolkits when we moved)
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 11-17-2011, 05:48 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #460 (permalink)
