CaptainCalf's Avatar
Did some head and cylinder measurements tonight to make sure I have room for Fire Rings...
There seems to be plenty of room around the head at approx. 8 to 8.5mm or 0.315 to 0.335" in width
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD
1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD
2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha
Old 03-23-2011, 06:32 PM
Cylinder Height
The cylinder height was approx. 2.5 to 3mm or 0.980 to 0.118"
Old 03-23-2011, 06:34 PM
Wiped the crank down. Now I've gotta blow out oil passages, measure clearances and track down all those bearings
Old 03-24-2011, 05:41 AM
350HP930's Avatar
Yeppers, one of the advantages of the 3.3 jugs is having lots of meat up top for all sorts of sealing options.
The bigger question becomes once you decide to go with sealing rings is who will you pick to do the machine work.
Old 03-24-2011, 06:13 AM
Mike over at JB Racing will zip them out for me
Old 03-24-2011, 06:14 AM
crank
One more thing to consider if its not done is to cross drill the #4 main journal and machine a full groove bearing to cure the oiling issue with rods 2 & 5, we can do that here as well, we drill out the alum. galley plugs and tap them for removable plugs as well.
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 03-24-2011, 07:13 AM
Let's do it Mike!
I'll bring the crank with me too. It's not a case of while you were in there but more about the fact that I want this build to be bullet proof
Old 03-24-2011, 07:18 AM
show your bikes if you gott'm
Side note
How many bike riding builders to we heave out there?
Old 03-24-2011, 09:11 AM
350HP930's Avatar
Looks like the color scheme of the 930 will match up nicely with a couple of your two wheelers, lol.
Old 03-24-2011, 10:35 AM
Everybody knows RED is the fastest color...just ask a policeman
Old 03-24-2011, 10:39 AM
350HP930's Avatar
True, but it looks so good, lol.
As long as you have Mike helping out you might also want to concider having him drill out the plugs in the cases so you can make sure the main oil gallies are all perfectly clean. Since the cases have been sitting a while you may want to consider replacing the squiters as well.
Old 03-24-2011, 04:51 PM
Will do!
Thanks,
Tony
Old 03-24-2011, 04:53 PM
bearings r us
bearings anyone or Stone IPA?
Old 03-24-2011, 05:48 PM
350HP930's Avatar
All of the above I say !
Old 03-24-2011, 07:15 PM
new case bonding techique
just install case through bolts and let it sit 5 yrs...no sealant required
Old 03-24-2011, 07:33 PM
more pics
bearings and heavy duty stand
Old 03-25-2011, 04:59 AM
350HP930's Avatar
Technically over time the clamped metal part's molecules will start diffusing into each other and bonding if they were clean enough when I clamped them together, lol.
Glad to see all the bearings held up well in their packaging despite sitting around in the florida humidity for the last several years.
Old 03-25-2011, 05:56 AM
It's a testament to how well you had it all preserved
Old 03-25-2011, 06:02 AM
rocker locks
Anybody running these TurboKraft rocker locks? Looks like a great idea to me...
Old 03-25-2011, 06:49 AM
350HP930's Avatar
Wow, looks like a good solution to secure the shafts and keep them from leaking.
My only condern from a technical standpoint would be is the width of the housing casing consistant enough to where they all clamp down on the rocker shaft securely enough?
Old 03-25-2011, 08:05 AM
