I've put clamps on push on SS lines that don't even need them, so you know I'll be clamping these;) |
Looks great though - looking forward to seeing the finished product. |
What a great project here. Thank you for sharing your journey with us all here. I'm inspired to go out to my garage and clean something. :)
PM me on that fuel accumulator... My engine is out but I think my accumulator was on the fritz last summer. (intermittent hot start issues) |
Last box of EFI parts
The final EFI parts are on the way, so I should finally have the motor in within a few weeks:p
In the meantime, I replaced the motor mounts with a set of sport mounts and pulled the flags for sanding, priming, sanding again, base coat, sanding again, top coat:) Anybody ever paint their flags black on a red car??? http://forums.pelicanparts.com/uploa...1326675904.jpg http://forums.pelicanparts.com/uploa...1326675913.jpg http://forums.pelicanparts.com/uploa...1326675923.jpg http://forums.pelicanparts.com/uploa...1326675933.jpg http://forums.pelicanparts.com/uploa...1326675942.jpg |
black mirrors... no affiliationhttp://forums.pelicanparts.com/uploa...1326735811.jpg
Thanks RSRFan, IMHO if those flags were flat or even satin they would look much nicer.
That would sorta match those satin black wheels and headlight rims I gave ya, lol.
Banner Red Flags
I decided to go back with the original color:p
Multiple coats of the base: http://forums.pelicanparts.com/uploa...1326739286.jpg Sanded slick as a baby's butt ready for clearcoat: http://forums.pelicanparts.com/uploa...1326739338.jpg |
Car is looking fantastic! Wish I had more time to work on mine. |
I bought both the adapter/seat base bracket and the sliders from Sparco. Sparco USA However, with your skills you could fab up the adapters in no time, but since they were so cheap I decided against making my own: cut/weld/grind/paint/repeatx2;) |
CV Joint Rebuild
Today I pulled the CV joints apart and found 1 outta 4 is acceptable to reuse, so I'm replacing all 4.
I took the time to label and organize the parts in case I reused them: http://forums.pelicanparts.com/uploa...1327182175.jpg http://forums.pelicanparts.com/uploa...1327182187.jpg http://forums.pelicanparts.com/uploa...1327182195.jpg http://forums.pelicanparts.com/uploa...1327182202.jpg |
Did you see a lot of galling on the balls, or the races? I've taken a lot of them apart over the years and the always seem reusable...
Not sure what kinda interval these CV joints should be cleaned and repacked, but I think 25 years is prolly pushing it:rolleyes: |
Cv
Rick, call me regarding your Axle and prep for them
Mike |
old CV joint detailed
I detailed the old CV joint with the least wear and it looks better then new:)
Here's my detail kit http://forums.pelicanparts.com/uploa...1327455124.jpg Here's what the inner & outter races look like before and after detailing http://forums.pelicanparts.com/uploa...1327455220.jpg http://forums.pelicanparts.com/uploa...1327455244.jpg http://forums.pelicanparts.com/uploa...1327455262.jpg |
one more cv detail pic
done & ready to go!
http://forums.pelicanparts.com/uploa...1327456021.jpg |
I don't think it's a good idea to work on ball races, because they are hardened (in your case probably no longer).
They will have too much play which can cause failure and wear immediately.. Look here: CV Joints, Part 1 |
| All times are GMT -8. The time now is 08:03 PM. |
