http://farm4.staticflickr.com/3294/2...213e874c_z.jpg PLX Boost & AFR Gauge by willtel, on Flickr http://img.photobucket.com/albums/v3...g?t=1275012948 |
One thing I love about my ScanGauge is having access to almost all my engine parameters via the ECU's ODBII port. Programmable gauges sure to have a lot of advantages when you want to measure a few different things and mix it up a bit.
http://i976.photobucket.com/albums/a...n/Gauge009.jpg |
Multi Gauge
Thanks for all the imput! I've decided to go with the DTAFast X-Dash so I can see everything all the time...
http://forums.pelicanparts.com/uploa...1329094352.jpg |
coil pacs mounted
I finally got some time to make some aluminum saw dust:)
http://forums.pelicanparts.com/uploa...1329094716.jpg http://forums.pelicanparts.com/uploa...1329094536.jpg http://forums.pelicanparts.com/uploa...1329094559.jpg http://forums.pelicanparts.com/uploa...1329094581.jpg |
Have to say, I do like the rear view mirror offering, looks very trick! |
New VDO Oil Pressure sender
I've decided to replace my idiot light sender in the back of the motor at the turbo oil stream with a new VDO sender to feed the new ECU and new x-dash.
I still have the oem sender in place up front too, so I should be able to see both for comparison.http://forums.pelicanparts.com/uploa...1329323765.jpg |
Sidetracked again!
Can anybody guess what I'm up to with these?
http://forums.pelicanparts.com/uploa...1329853094.jpg http://forums.pelicanparts.com/uploa...1329853394.jpg |
gonna make a wheel tire pressure monitoring system...?? :-)
Don't know but I bet it is cool like all of your other "tweaks"... |
http://forums.pelicanparts.com/uploa...1329856978.jpg |
very tastefully done & nice...the silver/polished area on the fuchs & tail pipe tips & anything else on the car...??
VERY NICE IN DEED...What exterior & interior color is your car...?? |
thats right...I thought your car was Red & Black...another favorite color combo of mine...
You sure are finishing this car off top notch wise...keep it up...almost there...!! |
I like the 17" fuchs - and that car above is one of my favorites... http://forums.pelicanparts.com/uploa...1329858041.jpg |
Jeremy, I forgot you had the RSRs on that race car of yours...they look sweet!
I haven't decided yet if I'll go fully polished or black background, but they will be 9x11x17s and should look pretty good with all that rubber either way... |
Fuchs
This is one of my favorites:
http://forums.pelicanparts.com/uploa...1329858927.jpg |
Ahh Jack's car is awesome.
Here are my track wheels - 17" weld ups made by True Design. http://forums.pelicanparts.com/uploa...1294087541.jpg http://forums.pelicanparts.com/uploa...1294087576.jpg (spaced out cause I had smaller rubber on there) (235/275 in this picture) |
Jeremy, they looks so good I'd run those all the time...just watch out for puddles:)
| All times are GMT -8. The time now is 02:31 AM. |
