-   -   The Beautiful Puzzle: 1987 3.3L 930 EFI Build (http://forums.pelicanparts.com/911-engine-rebuilding-forum/598040-beautiful-puzzle-1987-3-3l-930-efi-build.html)
gsmith660 09-20-2012 12:59 PM
I would not be as concerned with the turbulence as I am with the air having to make a sharp 90 rather than a smooth bend. It very well may be big enough to not cause a problem but if you were on the edge for airflow it would be a major restriction I would think.
350HP930 09-20-2012 06:30 PM
Damn Rick, sorry to hear about the bad luck with the turbos.
On another subject though, as a motorcycle and porshe guy you might appreciate the layout I've working on for my motor project. :)
http://forums.pelicanparts.com/uploa...1348190535.jpg
The crank is semi-spherical since it occupies the lower cylinder area. I wanted a super short connecting rods for maximum torque and it since it uses the crankcase as a pump I've got to keep the BDC crankcase volume to a minimum.
http://forums.pelicanparts.com/uploa...1348190844.jpg
CaptainCalf 09-21-2012 05:09 PM
looks very coolSmileWavy
will it produce enough electricity to run my house?
CaptainCalf 10-08-2012 10:55 AM
Martini Bike Build
While waiting for news about the 2nd turbo rebuild I've been busy building a custom bike. The bike's colors are all old Porsche color codesSmileWavy
http://forums.pelicanparts.com/uploa...1349718868.jpg
I should get an update this week on how the newly rebuild turbo is working out...
CaptainCalf 11-17-2012 09:16 AM
side project finished
My tunner should have turbo back from Garrett middle of next week, so dyno runs possible by next weekend. In the meantime, here's my initial startup for my bobber project:
Custom Bobber - YouTube
nocarrier 11-17-2012 09:57 AM
Nice!
Woo hoo!
CaptainCalf 11-19-2012 05:31 AM
1999 HD 1250 Martini Bobber build
Here it is hitting on both cylinders:
1999 Bobber sorted - YouTube
CaptainCalf 11-30-2012 06:26 AM
Turbo is going back in today
Garrett sent our turbo back today, so it will be reinstalled for the 3rd time and tested. If all goes well dyno tuning will be scheduled for next week! We should know what kinda power this baby will make soonSmileWavy
willtel 11-30-2012 10:47 AM
http://forums.pelicanparts.com/support/smileys/clap.gif
CaptainCalf 11-30-2012 10:50 AM
<img src="http://forums.pelicanparts.com/support/smileys/clap.gif" border="0" alt="">
Yeah, I'm pretty happy about it too;)
CaptainCalf 12-06-2012 05:41 AM
Dyno Day
Finally! We are planning to Dyno this pcar today. If all goes well we should have numbers later today or surly by tomorrow. Tuner said he'll try to keep it below 600hp, but I'll be more then happy with anything close to 500:eek:
CaptainCalf 12-07-2012 05:34 AM
In line for Dyno
I think today is a fine day for Dyno tuning!http://forums.pelicanparts.com/uploa...1354887234.jpg
PrimeMvr 12-07-2012 06:03 AM
mmmm......Porsches..... :)
CaptainCalf 12-07-2012 06:34 AM
Yep, it's like P-car HeavenSmileWavy
johnman001 12-07-2012 07:03 PM
Wish my 930 was red..... DROOL!
CaptainCalf 12-08-2012 02:49 PM
Not fully sorted yet, but very close! 400whp was all the boost the silicone jointed intake plumbing could hold, so pulling it all off and going back with all hard piping with crimped joints that will hold all the boost we want to make...
kjchristopher 12-08-2012 03:39 PM
Joining in late in the thread here - How much boost are you running and what clamps are you using? I run 18-22# on my boosted race motor (not a Porsche) and have zero problems with the silicone connections held by T-Bar clamps. Twelve different connections/clamps.
On Edit: Just found a picture - same clamps and hose I'm using. I'd think you'd be good up to the same boost I'm running.
JFairman 12-09-2012 11:17 AM
When I worked in a large porsche restoration shop doing body work here in West Palm that sometimes had 2 or 3 IMSA GTP teams working on their Porsche 962's there during the Florida races back in the mid to late eightees I remember those cars used silicone hose and either american made aircraft grade T-bolt clamps or they doubled up on the usual Zebra or Norma German hose clamps with two side by side on each end of the hose connections.
They used american made silicone hose and T-bolt clamps and didn't use thin wall low ply chinese silicone hose or cheap chinese t-bolt clamps. I don't know what you're using on your intercooler plumbing but they didn't blow off while running higher boost than you are during the Florida 24 and 12 hour endurance races.
If using american made hose and T-bolt clamps and one blew off maybe they just need to be tightened a little more. If using worm drive hose clamps put a drop of oil on the worm gear before tightening it.
CaptainCalf 12-10-2012 05:38 AM
Thanks JimSmileWavy It's mostly the thin walled stuff with a mix of clamps. We will rip it all out and go back with as much hard pipe as possible eliminating most of the joints, but we will be using high quality silicone & clamps this time if any are required. This should get us over this last hurdle to our goal of 500 ponies:)
CaptainCalf 12-10-2012 05:43 AM
Thanks KJC, it would prolly hold the boost as set up if tweaked properly, but I'd rather have fewer joints to have to worry about so we're gonna have some hard pipe fabbed up to fit snugly that should hold anything we decide to throw at it:)
