The pros and cons of twin plugging a 930 are certainly debatable and many of them are discussed in the following old thread . . .
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/396372-advantages-twin-plug.html When the engine is heavily loaded CHT is going to be one of the largest contributors to detonation which is why I think the known disadvantages of losing several square inches of head cooling surface area isn't worth a small tweak in ignition timing the twin plugging might give you. |
progress!
CHT + Boost = Ceramic Coating
Stay Tuned, PFM |
Measuring Valve Spring Heights
My plan is to get the heads built up this week, so I have a couple of questions. Are all 930 valves springs set to 34.5mm and what do you use to measure them with while shimming?
Also, do I really need a $50 tool to measure the height? Pelican Parts - Product Information: PEL-TOL-P228 Thanks, RC EDIT: I'll be running SC cams so that may affect the height wanted too and I read somewhere a builder recommended 33.5mm heights for 930s... |
sanded shroud
ready for painthttp://forums.pelicanparts.com/uploa...1306284499.jpg
rockers
Rocker refurbed by: Dougherty Racing Cams
Thanks John, they look better then new! RChttp://forums.pelicanparts.com/uploa...1306374246.jpg http://forums.pelicanparts.com/uploa...1306374273.jpg |
What Valve Spring Height???
I have a set of Super Cup cams, which I think are John's grind cuz they are stamped DRC.
I need to know valve spring stack height for new valve springs, so if anybody knows pls helpSmileWavyhttp://forums.pelicanparts.com/uploa...1306415368.jpg |
The rockers look great Rick.
As far as the recommended spring heights and related info, if its not on the cam card I would suggest contacting John for the details since you are the owner of his product now after all. |
SC on Turbo int/exh Duration at 1mm = 236/224 Duration at 0.050" = 228/218 Lift = 0.450"/0.395" lobe seperatrion angle = 113 lift@overlap setting 1.4-1.7mm |
he's good i lost the cam timing card from my ssc cams and last time i had the engine apart i called him and he knew right away what i had and what to time the cams at.
Cam Timing is set at 2.0mm. Valve spring open height 1.5 mm from coil bind. IF you plan on shifting over 7000 rpm, consider an aftermarket valve spring.
http://www.drcamshafts.com/profiles/supercup.htm |
Thanks John, I'll set them at 35.5mm +/- a frog hair and the warranty on these 2005 cams doesn't start till they are installed, right?:D |
good progess today
today's progress continued
Next heads
I get nervous when I see a nose bearing without the o-ring and the bearing case dowel installed.
Good eye and what you can't see is the missing dowel pin on order too:)
RC;) |
Heads getting assembled
2 down and 4 to go:D
http://forums.pelicanparts.com/uploa...1307016496.jpg |
| All times are GMT -8. The time now is 07:28 PM. |
