Kartoffelkopf
Cheers!....although neat and unintrusive, it's not ideal in terms of monitoring whilst on the move, too far out of the line of sight; I bought the additional screeching alarm to go with it. Via the laptop you set the max parameters for whatever you want to monitor, but not got it quite fine-tuned well enough yet (and now in the middle of my engine teardown/upgrade, so that won't get done for a good 3-4 months)
![]() PLX Boost & AFR Gauge by willtel, on Flickr
One thing I love about my ScanGauge is having access to almost all my engine parameters via the ECU's ODBII port. Programmable gauges sure to have a lot of advantages when you want to measure a few different things and mix it up a bit.
Multi Gauge
Thanks for all the imput! I've decided to go with the DTAFast X-Dash so I can see everything all the time...
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD 1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD 2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha |
coil pacs mounted
I finally got some time to make some aluminum saw dust
Kartoffelkopf
Have to say, I do like the rear view mirror offering, looks very trick! |
New VDO Oil Pressure sender
I've decided to replace my idiot light sender in the back of the motor at the turbo oil stream with a new VDO sender to feed the new ECU and new x-dash.
I still have the oem sender in place up front too, so I should be able to see both for comparison.
Sidetracked again!
Can anybody guess what I'm up to with these?
gonna make a wheel tire pressure monitoring system...?? :-)
Don't know but I bet it is cool like all of your other "tweaks"...
I live for 911 tweaks... |
very tastefully done & nice...the silver/polished area on the fuchs & tail pipe tips & anything else on the car...??
VERY NICE IN DEED...What exterior & interior color is your car...??
thats right...I thought your car was Red & Black...another favorite color combo of mine...
You sure are finishing this car off top notch wise...keep it up...almost there...!!
MBruns for President
Coasters?
I like the 17" fuchs - and that car above is one of my favorites...
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Jeremy, I forgot you had the RSRs on that race car of yours...they look sweet!
I haven't decided yet if I'll go fully polished or black background, but they will be 9x11x17s and should look pretty good with all that rubber either way...
Fuchs
This is one of my favorites:
Ahh Jack's car is awesome.
Here are my track wheels - 17" weld ups made by True Design. ![]() ![]() (spaced out cause I had smaller rubber on there) (235/275 in this picture)
Jeremy, they looks so good I'd run those all the time...just watch out for puddles
