laughac's Avatar
Send a message via AIM to laughac
connecting MSD 6AL to one-wire '87 930 distributor?
I'm changing engines and lost the paperwork for my MSD box.
Does anyone have instructions for connecting MSD 6AL to one-wire '87 930 distributor?
2000 Boxster S
2004 330ci convertible
1978 450 SLC
1924 Model T Ford touring
Fleet of Ford Buses, Sedans, SUVs and Limos
Old 03-24-2011, 10:28 AM
Send me a direct e-mail and I'll shoot you the instructions.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 03-24-2011, 12:46 PM
laughac's Avatar
Hi Steve,
I'm at Chris@Laughary.com
2000 Boxster S
1978 450 SLC
Old 03-24-2011, 06:09 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-24-2011, 06:36 PM
laughac's Avatar
Oh boy, I seem to only have one wire into my 3.3 disty.
I'll post a pic soon.
Thanks much!
2000 Boxster S
1978 450 SLC
Old 03-24-2011, 07:30 PM
Thanks much!
You have two, its a coaxial cable: a center conductor surrounded by a braided shield.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 03-25-2011, 12:38 AM
If you have the distributor coax wire polarity wrong at the MSD CD box the timing will be advanced quite a bit because the trigger signal from the distributor is a square wave and from what I've read the MSD is triggered at the end of the square wave when the squared off slope falls.
If you've seen a picture of the distributor's square wave from an oscilloscope or computer monitor it's easier to see that.
Both polarities will run the motor but the wrong polarity will usually make it idle higher because the timing is being advanced and that will very likely hurt the motor if you get into boost with it like that.
Old 03-25-2011, 08:43 AM
Two Rivers's Avatar
I thought it was AC voltage coming out of the dist. If thats the case what would it matter what wire went to what wire. Also isn`t the coaxial wire there just for RF interference.
Old 03-25-2011, 04:38 PM
I don't know about the 930, but the SC dizzy output is voltage ramp up (or down depending on polarity) followed by a rapid voltage reversal and another ramp down. The trigger is meant to be on the rapid voltage reversal. If you hook up the wires backward the MSD will trigger on the ramp instead of the reversal. This will be about 30 degrees too soon and is very ambiguous because it's not a steep ramp.
-Andy
Old 03-25-2011, 08:38 PM
