Chain fence eating turbo
Question New improved blue case through bolts o-rings? No need for the green vitons?
I spoke with a local Porsche shop that is pretty reputable and they told me that they no longer use the green viton o-rings.
They told me the new blue ones are tougher and have a 550 degree operating range versus the previous 350 degree range.
I said my kit came with blue ones from Victor-Reinz and he said, "yes, they made the change a couple of years ago to the new improved blue ones".
He also said they have had no problems with the new blue ones......
Anyone know about this?
I'm still hesitant due to this board.
Please set my mind at ease on which direction to go.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 03-17-2011, 07:09 AM
I used the blue ones and they leaked like a stuck pig! They came in the gasket set I sourced from our host last year. I had to replace them all with green Vinton o-rings and grease. NO SILICONE. The blue rings pushed out from under the washers when tightened.
Lindy
Old 03-17-2011, 07:41 AM
Dangit!
Old 03-17-2011, 07:44 AM
the green ones work, so try the blue ones if you want to take a chance. lots of fun doing another teardown. keeps your chops up.
206 637 4071
Old 03-17-2011, 08:12 AM
brads911sc's Avatar
They are 50 cents each. Not sure why you would even think about cutting a corner there. Buy the $12 worth of green ones... its nothing in the 12k price of a rebuild. You probably spent more than that on the brake cleaner you used to clean it. EBS or Henry have them in stock and you will have them within a few days.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 03-17-2011, 09:38 AM
Super Moderator
cstreit's Avatar
Never had a problem with the blue ones, but I lube them up pretty good when tightening the thru bolts so they don't tear as much.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 03-17-2011, 10:40 AM
Nope, only want to do it once...fingers crossed
I am not trying to cut corners.
1. I asked a question that if in fact the blue ones are as good as the green ones now.
2. Why would you order a common o-ring that you can buy at a local auto parts?
"Tear as much".....nuff said...
Old 03-17-2011, 10:52 AM
If you use the green ones just make sure the washers seat againist the case, I had a issue of them holding the washers off the case. Look at the face of the case where the washers seat to see if it is still flat, the washers can dig into the case a bit. Also see if there is a chamfer on the case.
Old 03-17-2011, 12:28 PM
Tippy,
If you are absolutely sure the the locally sourced rings are the same, go for it. But you need to make sure; something tells me they are not. With regard to the case having a chamfer, mine did not and the 3.0 litre cases I've seen do not. I don't know that a chamfer cut is necessary as mine is stock and came from the factory without a chamfer and did not leak. I'm not saying it's a bad idea just that it worked before the way it is without the case chamfer.
I must take exception to Waynes recommendation of using silicone with the o-rings. That in itself might be why the blue ones have a hard time staying in place during installation and squeeze out. The green ones may do the same if you try to use RTV or the like. I used silicone grease and the green ones the second time around and would only do it that way in the future. I'm a "If it works don't fix it" kind of guy.
Lindy
Old 03-17-2011, 01:47 PM
Try not, Do or Do not
Henry Schmidt's Avatar
We have been seeing absolutely atrocious quality in the Victor Rienz gaskets.
The most recent ( just this week) were 2.7 CE rings that are so cheap I wouldn't use them for a ring toss and out of round base gaskets. So badly out of round that they wouldn't fit on the cylinders.
Wrightwood Racing gaskets are the only way to go.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-17-2011, 02:47 PM
3.4 Bigger is better
88-diamondblue's Avatar
Agree with Henry. I used the Wrightwood racing set on mine and green viton o-rings. No leaks and quality was good
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 03-17-2011, 02:56 PM
Will keep an eye out, thanks.
Originally Posted by lindy 911 View Post
Tippy,
Yes, I will make sure, not going to jeopardize it. Viton is used in AC stuff BTW.
Argh....I've spent 100's of hours (over 27 months down) on this board researching and I have never heard of their quality being bad. I would have paid more if I'd have known...
Yeah, like I said above, I knew about the blue o-rings but not that Victor-Reinz quality is bad....
Old 03-17-2011, 07:58 PM
Green o rings verses Blue
Cory, for my rebuild I had read about this issues somewhere else on the forum.
That clinched the deal as far as I was concerned to go with the general consensus of using the green ones.
That is what I have now ordered for my rebuild
Ian (from one of those days)
Old 03-17-2011, 08:20 PM
Yeah, I have to get them this weekend.
I will report back if I in fact do find them in a parts house.
BTW, GL with your build!
Old 03-18-2011, 06:43 AM
ALEX P
ALEX P's Avatar
When I tore mine down it had the blue ones in there, I ordered a new set and they arrived black but for what they cost I just wasn't prepared to take the risk so got a set of green ones.
Good luck.
Old 03-18-2011, 10:18 AM
Ken911's Avatar
where do you get wrightwood gaskets?
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 03-18-2011, 12:09 PM
viton can be black too.
206 637 4071
Old 03-18-2011, 01:21 PM
sjf911's Avatar
1+
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 03-18-2011, 01:27 PM
Supertec
Henry Schmidt
Ph: 760-728-3062
Old 03-18-2011, 03:31 PM
Irrationally exuberant
ChrisBennet's Avatar
Here's what the blue o-rings do (scroll down to my post) for pictures:
http://forums.pelicanparts.com/911-engine-rebuilding-forum/291553-through-
bolts-seals.html
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 03-21-2011, 07:52 PM
