onepenney
Older engine in a newer 911- 964
Does anyone know if I can insert a 74 911 2.7 engine with a 901 transmission into a 1990 964 that currently has no engine or drive train? What issues can I expect - other than under powered.
Old 06-28-2011, 10:18 AM
Max Sluiter
Flieger's Avatar
Emissions regs in CA would mean it would need to pass 1990 specs.
Old 06-28-2011, 11:05 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Note that the 964 chassis uses a different type of transmission mount. It does not use the same common "dogbone" mount for the 901/915 The 964's G50 has a crossmember that bolts to a large circular rubber isolator on the tail case of the trans. Point being is the forward trans crossmember will be a slight challenge.
Kevin L
'86 Carrera "Larry"
Old 06-28-2011, 02:35 PM
Todd Simpson's Avatar
The major issues would seem to be shift linkage is different, axles are different and clutch actuation is hydraulic in the newer car.
Once you sort those the other stuff-throttle linkage, wiring and fuel pump would be pretty easy to solve.
Oh, no power steering provisions on the old engine.
Racer
winders's Avatar
Originally Posted by Black 993 View Post
He's not in CA.
I say go for it. Easy swap. Just document it here with pics and narrative.
If you are going to be sarcastic, make it obvious to those that don't know any better.
Scott
Old 06-28-2011, 03:04 PM
Less brakes, more gas!
euro911sc's Avatar
The engine work is probably fairly simple, but the trans is a totally different animal. It would be easier to source a correct trans and then figure out how to mount it to the 2.7 I believe.
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 06-28-2011, 04:55 PM
Max Sluiter
Flieger's Avatar
He's not in CA.
Thus the subjunctive.
Old 06-28-2011, 07:15 PM
Mr9146's Avatar
Why?
This project is so not worth the brain damage.
Old 07-01-2011, 10:03 PM
