Which Nut to Use?
About to seal up my case (again) in the morning and wanted to confirm that I am using the correct nuts to secure the oil pump before doing so. As of right now I am using the locking tabs and M8 Oval-Shaped Locking Nuts that came in my Pelican Super Parts kit. Any issues? Pretty sure that I don't want to use a nylon lock nut inside the case but wanted to confirm before closing it all up.
Thanks,
Rob Montgomery
'88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running
Old 07-09-2011, 09:53 PM
Try not, Do or Do not
Henry Schmidt's Avatar
We use a prevailing torque nut on all oil pump studs.
The factory uses a standard hex nut with a lock tab.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-09-2011, 10:14 PM
