Making a short stroke out on 2.0
Has anyone built and short stroke out of a 2.0? I was told you use 2.7 top end on a 2.0 bottom end. I guess this makes a high revving engine. I was looking for someone with this set up to ask a few questions.
Old 07-10-2011, 06:55 PM
Max Sluiter
Flieger's Avatar
That means 2.5 liter short stroke. 90mm pistons and 66mm stroke. The 2.0 already has the shortest stroke crankshaft of any production 911 engine.
Old 07-10-2011, 07:15 PM
2.5 short stroke
Is this a pretty good set up for a street car?
Old 07-10-2011, 07:18 PM
Max Sluiter
Flieger's Avatar
If you like revving to the moon around town and have short gear ratios, then yes!
Old 07-10-2011, 07:26 PM
As Flieger stated, 89 or 90 mm cylinders on a 66mm crank gives you a 2.5SS. If you already have the 2.0 case, great you can go with that ( with some work) and if you do not you can go with any of the later cases, 2.2, 2.4, 2.7 with the 66 crank.
I am running a 2.5SS on the street and really like it. Mine is pretty built but I have been in others, you can putt around town just fine but most 2.5s need/should be reved to get the most out of them...... If not why even go short stroke.
Jimmy
Old 07-10-2011, 09:36 PM
Danimal16's Avatar
I just got my 2.5 SS back in my 71. This engine is FAR more streetable than the old T engine that it replaced. I have the stock 901 (911) gears in the transmission and went with Mod Solex Cams. This thing is a stump puller. The power band is just a HUGE improvement. I would do it again.
DanB
Dan
Old 07-11-2011, 04:58 PM
