2010 GT3 Crankshaft Part number
Looking for the part number for the 2010 GT3 Crankshaft. I know it runs $1800 from the dealer, but the parts department at the dealership near my home, the counter monkey has no clue..
TIA.... |
$1,623 from Pelican
1970 911E - track / weekend car 1970 911S - under restoration 1986 930 Slant Nose - fun car |
Gt3
That is interesting Andrew15, the dealership is $1800, and I know there are two or three variants of GT3 shafts. We are in the process of a CMW stroke rebuild after snapping a CMW ground 3.0 shaft, and the realization that another grind is futile. We plan on a GT3 shaft and custom rods from Charlie at LN.. 132mm to be exact. With 100mm jugs.
Let me look into this PP pricing.. Thanks! |
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Here is the original build of the CMW engine.
Euro SC case CMW Grind on a stock 3.0 crank to 77.5 Custom Cunningham rods 130mm Custom JE Pistons 100mm with Mahle Motorsports 100mm Cyls So, since the crank snapped due to the over machining of the rod journals, which breaksout at the oil passages, we are going with a GT3 crank and 130.5mm rods to get us back to the deck we need. TurboKraft has done similar mods with a GT3 crank, so it should be ok.. |
I was just looking into sourcing one of the 2010 GT3 crankshafts
but there is none to be had -- even in Germany, back ordered indefinitely. alternatives in the same performance/price range? m
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo 2001 996 GT2 1999 Spec Boxster, 1996 993 Cabriolet 1992 964 Cabirolet, 1975 911 RSR Replica Race Car |
R.I.P.
I know I'm digging up an old post but is this crank still available? I'm looking to run one in my 930 motor
I keep hearing they are back ordered so long that there is no date. turbo kraft got about the last one avaiable and they havent been able to get any more of them. I think henry schmidt was going to have another batch of his custom super tech cranks made up. If you did that you would still be able to use the set of rods you have.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's. 2019 Silverado 6.2L Last edited by Ken911; 08-12-2011 at 04:40 PM.. |
abides.
I don't know how/if it differs, but I recently saw
Try not, Do or Do not
We generally have one or two in stock.
Email me for price.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
