Question A little advice needed on a 3.3 turbo engine.
I had some blue smoke when i had a buddy behind me so i did som investigating. Some oil coming into the turbo inlet and the turbo i think is ok.
This is how 5 cylinders look like.
ImageShack® - Online Photo and Video Hosting
This is center cylinder drivers side. #3?
I asked in 930 forum and got tips but hope someone here know or have seen this before.
Jump on it with tips of what to check please
Oheggem
Old 09-08-2011, 04:45 PM
BoxxerSix's Avatar
Worn exhaust valve guides commonly lead to blown stem seals. Have you had a leakdown/comp test performed on the motor?
Adam Hennessy
Old 09-08-2011, 04:48 PM
No i did not. I was hoping it was just a valve stem that is gone. If this seems to be either valve guide or stems then i think i`ll try changing the valve stem without taking out the engine as i have very limited space and hope that fixes it for now.
Got a bit worried about maby piston ring or similar.
Old 09-09-2011, 03:36 AM
Tim Allen is my HERO!
Originally Posted by Oheggem View Post
......If this seems to be either valve guide or stems then i think i`ll try changing the valve stem without taking out the engine .......
MMmmmmmmm??????
How does one go about doing this?
Old 09-09-2011, 05:52 PM
