(man/dude)
Jonny042's Avatar
Used GT3 crank - yay or nay?
Hello all,
I am looking at a used GT3 crank that the seller says has 40 hours (1 season) of racing on it.
I am willing to assume that dimensionally the journals are as original....but....without knowing for sure the history,
Should I run away as fast as I can? Buy it if it is one piece? Have it magnafluxed?
Thanks, Jon
PS - For street use, 3.2, maybe with 98 pistons. Still planning and buying building blocks.
Old 12-01-2011, 06:31 PM
BoxxerSix's Avatar
If you don't buy it I will.
Adam Hennessy
Old 12-01-2011, 07:44 PM
GrantG's Avatar
That would make for a mean 3.5. I would think a good crank specialist could inspect it and give you some confidence (either way).
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica
Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods
Old 12-01-2011, 09:36 PM
(man/dude)
Jonny042's Avatar
Yes.... that's what I was thinking....but only AFTER it's mine.
So it's a matter of risk assesment - I know the consequences, but what are the odds?
I am tending to think that if it shows no signs of scoring or wear then it's most likely not cracked, fatigued, or bent, and that it would be worth buying, checking, and using.
Anyone know the cost of magnafluxing a crank?
Old 12-02-2011, 06:08 AM
KTL KTL is online now
Schleprock
KTL's Avatar
$70 at Active Engines?
Active Engines | Crankshaft Services, Mississauga
Kevin L
'86 Carrera "Larry"
Old 12-02-2011, 09:38 AM
Try not, Do or Do not
Henry Schmidt's Avatar
New GT3 cranks are available from Supertec for $ 1,880 so why risk a used crank?
Remember that most GT3 cranks spend a great deal of time under full throttle situations and at over 9000 RPM. I think under those conditions a crank only has a limited life.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 12-02-2011, 09:48 AM
