Originally Posted by BURN-BROS View Post
Are the numbers right on the spreadsheet
Aaron, I agree with this observation and I have serious doubts about the validity of this data.
A typical engineering steel would have an expansion of about 13 ppm/degC rather than 10.
All Auminium alloys I have knowledge of have a figure of at least 19ppm/degC and 21 would be a more realistic estimate for an alloy with relatively low Silicon.
Elektron (Magnesium) Alloys are more likely to be around 25ppm/degC
I belive Dilavar is about 18 ppm/degC
17-4PH (Precipitation Hardened Martensitic Stainless Steel) is about 10.8 pp/degC
All of this expansion data is based on measurements taken at 20 degC and there will be some minor variations at 200 degC but similar trends would be observed.
I beleive that clamping force increases with temperature in all cases.
Clearly in the case of Dilavar this increase is relativley low and if you only use Dilavar on the lower studs there will be an uneven distribution of force on the studs and barrels. I am not sure this is entirely christian and not something I would generally recommend.
The 'standard' steel stud would give a moderate increase in clamping force and the 17-4PH the highest increase.
It is interesting that ARP's 'best' material is Age 625 and this an 'Inconel' type alloy which is Nickel based and offers extremely good high temperature properties but has a typican expansion of 13ppm/degC and is very similar to a standard steel stud.
Just for interest Titanium 6AL4V a typical alloy used in race cars has an expansion of about 9.5ppm/degC.
Old 12-22-2011, 12:27 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Just a quick review: Please bear with me as I intend to make some assumptions and all of this is from a rather marginal memory.
Porsche engineers starting with a clean sheet of paper and all the material data sheets designed an engine with specific torque specifications.
I assume they selected the head torque specs with the understanding that the steel studs would not expand as much as the aluminum case, heads and Biral cylinders. The torque value selected would (by thermal expansion) increase the clamping pressure as the engine heat increased. They knew this so they either wanted an increased clamping pressure or felt that an increase would not be detrimental. (I’m of the opinion that they wanted the increase). These engines had few if any head sealing issues
Next, they redesigned the case and in that design they change the case material from sand cast aluminum to die cast magnesium. No change in head torque value and no stud issues. As the case specifications progressed so did the cylinder material. Case spigots got larger and the cylinder changed to Nikasil coated aluminum and high silicon Alusil an aluminum alloy with 17% silicon. If high silicon aluminum expands differently that "standard aluminum" wouldn't you expect to see a different stud or at least a different torque specification? Once again, no torque specification changes from the world class engineers. It wasn’t until customers super-heated the engine that stud issues appeared. It was assumed that most head sealing issues were attributed to a loss of clamping force because the head studs were pulling from the case.
At that point, Porsche redesigned the case to accommodate a larger cylinder and specified die cast, high silicon aluminum as the case material. Early die cast aluminum case came with steel studs and of course no stud torque modification. This new case seemed to resolve the pulling stud issue.
The later aluminum case engine is where we started seeing Dilavar (24 in the turbos and 12 on the NA cars). It was around this time that we started seeing head sealing issues. Yes, your right, no stud torque change even on the engines with differing studs. I wonder if they had the same engineering back ground as the experts in the thread. Didn’t they know about clamping pressure and thermal expansion? It was in these engine that we started to see head sealing issue that weren't related to loose nuts (pulling studs).
Within a few months, we started to see stud failure in new street cars. Warranty departments were beside themselves. I even had a brother in-law with a 78 SC who needed me to repair his 16,000 mile one year old car.
The engineers figured the issue was corrosion so they epoxy-coated the studs and decided that all 24 studs should be Dilavar. Did I mention that the "new/coated" Dilavar still broke, sometimes while the engine was on the stand? It was at this point that I started having my doubts about Dilavar. Did I mention there was no head torque specification change? What about clamping pressure?
Porsche stuck to its failed stud for a decade or so until they abandoned the Dilavar for a steel stud. Still the same torque spec.
Shortly thereafter, they came up with the all-thread (looks like a hardware store remedy and how do you engineers feel about a stress raiser in the center of a stud?) that would presumably alleviate the breaking issue. I will admit that the all-thread is less likely to break, although we do see breakage and we continue to see head sealing issues. The torque specifications were changed somewhere along the way but if I remember correctly they went from ft/lb or NM to a torque angle which produces, you guessed it, the same pre-load as the ft/lb method. Wait , wait, wait, what about clamping pressure?
So tell me again, why shouldn’t we try something different? And after testing that “something different”, if it passes the real world trials why shouldn’t we use it ?
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 12-22-2011, 08:15 AM
Thanks for the history lesson
I don't think anyone here is saying that you ought not try something new or continue to use it if it works. The real question being asked is "Why?! Why does it work better?"
I wouldn't hesitate to use your studs in a rebuild; in fact, I'm certain I would. At the same time a good engineer wants to know the why of it, and, if his (her) hypotheses don't match reality to figure out what he (she) has missed. The answer in this case *should* be knowable from a technical standpoint; there's no theoretical physics here- it's all well documented old stuff. Something's been missed is all; the facts are the facts and if we can't match hypothesis and reality the failing is our own and not with the immutable laws of nature!
Seriously, there has to be an explanation. To some, this is germain; to others, less so. I'd love to know, but I'm that way. At the same time if the bigger brains can't figure out the why I'll be happy with the 'what' of "These are currently the optimum choice if you need new studs."
Old 12-22-2011, 08:45 AM
The search for enlightenment is noble and discovery is rewarding but to continue to use a product that has a failure rate that is unacceptable because you don't know why it fails may be boarding on OCD.
Insanity is "Doing the same thing over and over again and expecting different results" Albert Einstein
Henry Schmidt
Ph: 760-728-3062
Old 12-22-2011, 09:42 AM
Henry,
There are of course several interesting issues that come out of this history and it is worth looking at some of these issues on a point by point basis.
It would be standard practice for any designer to consider the influence of expansion on clamping forces and the effect that this would have on both studs, pull out loads and the potential of yielding to occur in compression.
If I were designing a joint of this type I wouldn't look for an increase in clamping due to expansion as I would want enough preload to eliminate the fatigue loadings produced by the peak cylinder pressures but I would want to be sure that I didn't cause any failures due to increases in the forces.
The sand cast cases were likell to have been a 'Eutectic' alloy which would be about 12% Silicon and this would have expansions in the order of 21ppm/degC.
The load bearing capability of the Elektron casing must also have been considered to be adequate for these loads.
I am not sure about the material used for the Nikasil barrels but if it were a typical wrought alloy its expansion could be as much as 24ppm/degC.
The 17% Hypereutectic Alloy developed by KS can be used without liners by etching away the surface aluminium and leaving a small surface of Silicon.
These alloys expand about 15% less than wrought alloys - about 20ppm/degC.
There is a potential issue with the cast aluminium/silicon engine cases and that there is the possibility of silicon migration within the solid phase at temperatures around 200 degC.
This means that silicon particles within the component can grow which depletes the silicon in neighbouring regions and causes a local weakening of the matrix.
(This can be one of the causes of failure of Eutectic and Hypereutectic Pistons and why 2618 is preffered for high end Turbo engines.)
I am sure there must be some detailed information about the behaviour of these alloys but it has not been extensively published.
The die cast aluminium cases would not be too different from the sand cast cases in terms of material expect that the Silicon Morphology is likely to be more even in terms of both size and distribution.
There is, of course some porosity issues with die castings compared to sand castings.
Gravity die castings and even low pressure die castings tend to have low levels of porosity but they can exhibit porosity evenly throughout a structure (many die cast wheels leak air and now the trend is to powder coat to seal them.)
The composition of the case is interesting and in general die castings would be made from a Eutectic Alloy.
This is a Silicon content of about 12.6%. This composition has two adavatages.
The eutectic composition gives the lowest melting point of any Al/Si alloy and hence heating cost is minimised. The second is that Eutectic alloys don't have a freezing range. They remain liquid to a specific temperature and the solidfy evenly and uniformly with a change of only a couple of degrees.
This means that components can be reaily knocked out a die as soon as they ahve cooled, you don't ahve to wait the hundred or so degrees (freezing range) of alloys such as 2618.
These two charcteristics significantly reduce casting costs.
I am sure the stud pulling issue was a feature of magnesium combined witj Nikasil and thermal reactors increasing engine temp.
There is no doubt that Dilavar suffers significant sensitivity to Stress Corrosion Cracking in the presence of Chlorides (salt on the road is a great way to introduce chlorides to the studs).
Stress Corrosion Cracking is a very specific form of corrosion. the chlorides attack the grain boundaries of the material and effectively form a very sharp crack.
When the crack has elongated sufficiently to reduce the remaining area of the stud it can no longer support the load and it will suffer from a brittle failure.
There is a whole science (Fracture Mechanics) devoted to this type of failure but the crack length, crack tip radius and the stress intensity all contribute.
I have to say that apart from manufacturing defects there is no failure mechanism that would result in the brittle fracture of a new stud which had been loaded a left in an engine stand.
It would be good to look at the fracture surface of such a failure - probably with a Scanning Electron Microscope as there is bound to evidence of a defect.
Porviding the clamping loads have been correctly established there is no real reason why Dilavar should give problems due and why heads should lift.
I am suspicious about casing stability and stress relaxation where studs would pull in magnesium cases. Increase in Silicon content is likely to make this worse.
I would agree that the 'all thread' stud looks terrible but the tip root radius of the thread doesn't really cause any significant stress riser in this application.
i different geometries tip root radii of about 0.2mm would be an issue but not in studs or bolts in the type of materials we are disussing.
In fact the probable reason for the all thread is to ensure that any deformation is evenly distributed along the length of the stud - something which the thread will help to achieve.
If you take a bar with a single notch and put into a tensile test machine it will clearly fail at the notch. You would also need to measure the elongation at failure.
If you take a length of the same bar (cut adjacent to the first test length) and machine a series of multiple notches the failure load will be identical - within experimental scatter - but the elongation will be significanltly higher.
This does, of course, also need a material to have some ductility so ceramic bars wouldn't behave this way.
The all thread also have a slightly larger minor diameter than the plian stud so for a given prload will be slightly less stressed.
I am not sure why you would change the way you the nut on a stud from simple torque to a torque + angle and this needs some thinking about.
It may be to try to have a more even preload .
Torque to axial force using torque wrenches tend to give axial force variation of +/- 25% and this could be part of the issue with increased capacity and hence combustion loads.
Old 12-22-2011, 10:36 AM
Max Sluiter
Flieger's Avatar
If 12% is eutectic, then wouldn't 10% Si be hypoeutectic, not hypereutectic?
The KS "Alusil" barrels were meant to be the wear surface and were run with hard, iron coated pistons. The MAHLE "Nikasil" barrels were meant to be the hard surface with their thin Nickel-Silicon-Carbide coating on the Aluminum barrel and were run with a normal Aluminum piston and relatively soft rings.
The MAHLE alloy for pistons and cylinders is a higher Silicon content than the JE alloy, which is the one more stable at high temperature but a little softer and with more thermal expansion. I do not remember the numbers but there was a thread on here about materials for making new, CNC machined heads that discussed alloys. chris_seven was the main contributor.
Old 12-22-2011, 11:00 AM
Max Sluiter
Flieger's Avatar
And a mean tensile stress reduces the fatigue endurance limit. So I would want to have the minimum preload (at any temperature) to be just enough to overcome the cylinder pressures and keep everything from fretting.
Or were you referring to the Aluminum fatigue? Well, Aluminums do not exhibit a fatigue endurance limit and even if they are in compression the polycrystalline nature will mean that there will always be some grains oriented in a bad direction that will be loaded in shear or tension which can start a crack even with cyclical compressive loads.
Old 12-22-2011, 11:04 AM
Found this information about Dilavar:
Dilavar (Ni 13 (Nb NiMnCrV X 68 12 5) - Material No. 1.3937)
It is a nickel alloy.
I also found this text on the Lnengineering website:
On 911 models, certain engines came fitted with Dilivar head studs, which were designed to match the expansion of the cylinders, but also suffered from hydrogen embrittlement, which is a condition that results from the accumulation of hydrogen gas in the atomic structure of the metal.
If hydrogen embrittlement is the cause, and not SCC, it can explain that the bolts fail at the engine stand. In my previous job the same thing happened with new bolts on oil equipment, even before it left the factory.
Old 12-22-2011, 12:43 PM
Speaking for myself, this has been a fascinating and educational thread. Learning new things is the main reason I go to work every day and this one has been all of that.
This discussion has certainly shed renewed light on this subject and offered the variables that may help explain why people have varying experiences with all the head stud options.
My heartfelt thanks to all the participants who have contributed their engineering and metallurgical expertise and hopefully made all of the readers a little smarter.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-22-2011, 03:45 PM
Sorry 10% was a typo - should have been 17% - which is hyper -- 10% would indeed be hypo.
4032-T6 is very similar to the Mahle Alloy and the Silicon does reduce the expansion by a significant amount but also reduces the melting point and hence - in general- the softening point.
One important property of materials used at elevated temperatures - an aluminium at piston crown temperatures is just such an application - is the -equi-cohesive temperature. This the point at which grain boundaries in the material start to slide over each other and allow deformation.
2618 is better than 4032 in this respect. The pistons that used to be used in Mercedes F1 engines had a Beryllium content - since banned and this alloy is not only stronger, stiffer has better thermal conductivity but is also more resistant to creep - sorry to drift off the subject.
I agree that preload should be a minimum and I think I said in an early post that anything that increased the pull out force was undesirable.
I don't think fatigue in the studs us a major concern but studs will generally be designed to have enough preload to avoid fatigue loading.
I am not sure what you mean about the 'bad' orientation of grains in a Aluminium based material. Aluminium is face centred cubic which means it has 12 slip systems available to allow deformation so its its behaviour is generally quite isotropic.
Most metals that exhibit fatigue endurance limits have 'interstitial' alloying elements. These interstitial atoms block the movement of dislocations and inhibit the formation of the slip band intrusions and extrusions that usually initiate fatigue cracks. Interstitial atoms such as carbon are quite small.
Aluminium atoms are already quite small and the vast majority of alloying elements are subsitutional and these don't much change fatigue behaviour other than to increase strength.
The precipitation hardening alloys also don't really produce fatigue endurance limits as precipitate particles are again relatively large.
Stell at room temperature is Body Centred Cubic and there is a large octahedral interstital site which can be occupied by a Carbon atom and this is generally responsible for the endurance limit.
If a 'bulk' material is loaded in compression the orientation of individual grains will not lead to the production of fatigue cracks. As you say you will always need a traction vector to generate a crack. If you load a material in hydrostatic compression it will not fail even if it is polycrystalline as are the majority of day to day metals (Gas Turbine blades are single crystal to eliminate grain boundary sliding). I think you will only see resolved shear stresses at surfaces where buckling or other geometric instabilities occur.
I do think, however, that at around 200degC Aluminium/Silicon alloys can exhibit fatigue softening due to variations in tensile loads. The more highly loaded the stud the more likely this is to occur. This mechanism would almost certainly cause a loss of preload.
I don't think you can call this a Nickel Alloy. The convention is to name an aaloy after the main alloy constituent and 13% Nickel is almost ceratinly described as a Stainless Steel. The fact the studs are virtually non-magnetic is a good guide to the fact that the crystal structure is Austenitic in nature. Stainless Cutlery Steels, which are ferritic are about 13% Nickel. The other elements present help to stabalise the Austenite phase to remain at room temperature.
Materials such as Inconel 718 which are similar to ARP's Age625 are around 55% Nickel and are traditinally known as Nickel Alloys.
The Hydrogen embrittlement theory is interesting.
Hydrogen embrittlement is a reasonably common phenomenon but there must be a souce of hyrogen for this to be a problem.
In oil/gas environments knows as 'sweet and sour' gas there is always hydrogen present in pipelines and this hydrogen can and does diffuse into plant and equipment and casues significant problems. The hydrogen normally needs to be in an atomic form to diffuse into a metal and is normally the result of a reaction rather than in gaseous from.
Electroplating high strength bolts can also produce atomic surface hydrogen if plating is not extremely well controlled and it is common practice to de-embrittle plated bolts particulalry in a areospace environment.
If Dilavar is a precipitation hardening Nickel Alloy then its susptibility would be much reduced compared to conventional high strength steels.
Nickel based alloys of this type are the material of choice for most 'Hydrogen' applications.
It is also true to say that many of the high strength precipitation hardened stainless steels can be suseptible to Hydrogen embrittlement but would need to operate in an environment wher hydrogen was present.
A salt water environment could help to induce this type of problem but parts would need to immered for significant amounts of time for this to become an issue.
There are two ways to reduce the sensitvity of Preciptitation Hardened Stainless Steels to hydrogen embrittlement.
The first is to heat treat them to an over-aged condition which lightly reduces strength. but is beneficial.
The second is to add Niobium to the alloy composition.
It is interesting that Niobium is present in Dilavar.
I think it is unlikely that the studs pick up hydrogen in their operating environment and if they did then conventional steel would suffer in the same manenr as would 17-4PH which could be worse.
It may be possible for Hydrogen to have been introduced into Dilavar at some manufacturing stage - such as during acid pickling but it does seem unlikely and would have been relatively easy to resolve and eliminate.
If a bolt or fastener has a prior defect such as a hydrogen crack the loading it to a specific conditon that does not cause failure will mean that it is in a stable condition and providing the stress intensity at the crack tip doen't increase there will be no mechanism to cause a brittle failure.
The propogate a crack in an unstable manner the crack tip has to be provided with additional energy - the stress intensity must increase.
The only explanation can be that the fastener has a prior defect and that it has been initially loaded to a level just below the critical stress and then left.
If there is then some expansion or contraction taking place due to temperature change the KIC of the material could be exceeded and fialure would occur in a brittle manner.
This would only be true for very high strength materials and the 'cracks' would have to quite large.
My conclusions in general are that I would tend to use standard steel studs in standard engines. I would be tempted to use Dilavar or A286 in Magnesium cases with Nikasil barrels and would use Supertec Studs in high performance motors.
Old 12-23-2011, 04:11 AM
Originally Posted by Weissach911 View Post
..............There are two ways to reduce the sensitvity of Preciptitation Hardened Stainless Steels to hydrogen embrittlement.
The second is to add Niobium to the alloy composition....................
During the development stages of the Supertec stud, the engineer considered hydrogen embrittlement a possible challenge and in response to his concern, he called out an aging process as part of the preparation for thread rolling. The studs are cut to length, ground twice (each end is different), aged, threaded, ground again (tips and body) and inspected.
Last year we considered cryogenics as a possible enhancement but after Cryo treating and laboratory testing we discerned no appreciable benefit.
The stud is in a constant state of evolution with this years development being a second stud with a length change for better fit in water cooled GT3 and we're currently testing a flanged, 12 point, titanium nut.
Henry Schmidt
Ph: 760-728-3062
Old 12-23-2011, 10:15 AM
Max Sluiter
Flieger's Avatar
...I agree that preload should be a minimum and I think I said in an early post that anything that increased the pull out force was undesirable.
Steel at room temperature is Body Centred Cubic and there is a large octahedral interstital site which can be occupied by a Carbon atom and this is generally responsible for the endurance limit.
I do think, however, that at around 200degC Aluminium/Silicon alloys can exhibit fatigue softening due to variations in tensile loads. The more highly loaded the stud the more likely this is to occur. This mechanism would almost certainly cause a loss of preload....
What I was trying to say was that this is not a case of uniform, triaxial normal stress, at least the far field stress. The compression is in one direction only and so Mohr's circle tells us that there will be orientations that will see shear stress. Combine that with the pressure in the cylinder which sets up a tensile hoop stress and there will be tension in the material. Aluminum's many slip planes combined with the polycrystalline nature should mean that there will always be a stress to cause fatigue. And since Aluminum alloys do not show an endurance limit there is nothing that can be done to the stud torque that will cause them not to fatigue, though their lives can be extended by using minimal pre-load.
Old 12-23-2011, 10:44 AM
I agree that materials will fail in uniaxial compression, and there will be shear stresses developed in this case. The point I was making was that grain orientation in ductile materials does not influence this failure as there are plenty of slip systems available. If it were a brittle material the presence of cleavage planes would make this a different situation.
I don't think stress has anything to do with polycrystaline materials. The crystal structure will clearly influence failure stress and failure modes but unless yielding occurs I am not sure there is much influence.
It is possible that elastic modulus could be slightly anisotropic but this is a bit too deep for the macroscopic behaviour we are considering and I would model for elastic behaviour that is entierly isotropic.
If you know the principal stresses than you could contruct a Mohr's Circle and predict failure stress. By drawing the Circles for Uniaxial Compression and Uniaxial Tension on the same axes you can derive an Circle for intermediate conditions and when stresses exceed this envelope failure will occur.
I think that the Mohr's Circle approach is, however, a little too conservative and think a simple maximum Normal Stress Approach is bit more appropriate.
I am not sure that the stud location of the case sees much of a hoop stress as the peak cylinder pressure only occurs within a few degrees of TDC and there will be a steep gradient along the liner. I am failry sure that the tensile loads produced will be the most significant.
I think that the most appropriate model is to consider the threads in the case and look at the stress distribution in this area.
It would be interesting to carefully model this aspect of the design with a good FEA package and try to evaluate the influence pf preload, temperature and peak cylinder pressure.
Old 12-24-2011, 01:48 AM
Are the numbers right on the spreadsheet?
Part of the confusion surrounding this discussion is the questionable voracity of the data we assume is accurate.
Does all aluminum perform the same under changing environments?
Has the material that we laughingly call Dilavar been accurately identified?
Could Porsche engineers have had an ulterior motive or agenda beyond performance or cost savings when "Dilavar" and stud design was selected?
When Aaron asks "Are the numbers right" any impartial observer would be forced to admit "who knows".
This discussion has gone to a place that honestly leaves me feeling a little inadequate, so I think I'll be leaving.
Thanks for letting me play, I'll collect my parting gifts at the door.
Henry Schmidt
Ph: 760-728-3062
Old 12-24-2011, 07:24 AM
studs
I would like to ask a specific set of questions, with emphises on cost and end result.
1 In a Mag case 2.8 engine with Nikasil cylinders putting out 300 h/p which studs are recommended?
2 In an aluminum case 3.0, or 3.2 engine with Nikasil cylinders putting out 315 h/p which studs are recommend?
Please take cost into consideration, I have no need to brag how expensive my rebuild was, or that my studs will support the Titanic. I just want something that will not fail, and costs the least.
Mike
Old 12-24-2011, 11:08 PM
Mike
Hi Mike,
I think you'll get varied opinions to your questions here so I'll simply offer mine, FWIW.
1) Personally, I'd use the late 993TT Dilavars in a mag-cased, high-HP 2.8. Mahle cylinders must be modified for these as they are slightly larger OD than the steel ones. Naturally, case-savers are always installed to properly anchor the studs and strict oil temp control is mandatory for maximum durability.
2) We like the same 993TT studs in these engines to maintain consistent head clamping forces through the range of operating temperatures.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 12-25-2011, 12:36 AM
Constitutional Liberal
Turbo_pro's Avatar
Mike
I've had 4 engines rebuilt within the last 9 years. Two mag case and two aluminum case engines. The first one was a 450hp turbo followed by a 2.5 SS, a twin plug MFI 3.2 and a 2.45 twin plug with 40 Webers making 180 RWHP. Three had Dilivar studs in them when disassembled. They were all built with Supertec studs and none show any signs of head to cylinder leaking that was present in my Dilivar engines.
Originally Posted by KTL View Post
I think I can provide another example of Henry's experience with Dilivar studs. My '79's engine was built with all Dilivar studs. It exhibited the same condition that Henry's picture shows. Leakage above and below the cylinders.
I am quite sure your studs (Supertec) work reasonably well and have never criticised them and do understand the thinking behind the material selection .....................
Posted by an engineer who offered us such a thorough analysis of the material properties and their function in this every changing environment.
The Supertec stud has far more than just a superior (debatable for sure) material.
The fine thread 12 point nut is a far superior design both in material and functionality. No designer of high performance hardware calls out coarse thread unless threading into soft material. Rarely/never with a nut.
The extra thread length for more thread engagement in the case. Thread engagement to resist pulling
Spark plug clearance for twin plug application. Barrel nuts used from 64-89 will interfere with the spark plug in an twin plug conversion.
Corrosion resistant material that will never break (any fair jurist will admit that even new Dilavar studs break) and the nuts will never seize on the stud (common with Dilavar)
No installed length issues that slow down assemble time. Ask engine builders if they ever had an issue with stud install height. With the install length issue resolved you can install the piston and cylinder without the studs in place making pin and clip installation far easier. Without the studs, you can install the piston in the cylinder on the bench and install the P&C as a unit.
During this discussion there was little or no mention or debate about the other features of the Supertec studs. Why is that?
Below are prices on some studs offered by our host.
Pelican Racing Head Stud Hardware Super Kit - 24 RaceWare Head Studs, 24 RaceWare Head Nuts, 24 RaceWare Head Washers $909.85 no guaranteeI stand corrected they also have a lifetime guarantee.
Dilavar Cylinder Head Stud (sold per each, 24 required), 911 Turbo (1976-89)
Brand: OEM $41.50 $996.00 without nuts & washers no guarantee
Supertec Performance Cylinder Head Stud Kit (sold as a complete set, hardware included), 24 studs, 24 washers, 24 flanged nuts $660.00 Life time guarantee
Jim
“Rhetoric is no substitute for reality.”
― Thomas Sowell
Old 12-26-2011, 08:03 AM
It is difficult to consider some of the other features of the Supertec studs without sounding critical and as if I don't like these parts so I would start by saying that in general they appear to be well made and good quality and offer reasonably good value.
As is the case with the material selection, the 'other features' would also bear looking at from an engineering point of view.
1. Longer thread engagement into the case
It is well understood that load distribution along a thread is not uniform and the majority of the load being supported by the first engaged thread.
As a general guide once a thread engagement of more than 5 pitches the thread pitch tolerance accumulation pretty much guarantees that there will be unequal load sharing in the thread engagement.
Also the longer the thread the more difficult it can be to install and the thread as pitch errors can cause seizing.
As a rule of thumb it is not usual to design studs with a thread engagement beyond 1.5 to 2.0D.
If you need to ensure that the root shear stresses are lower than the tensile stresses in the stud so failure always occurs in the stud you should reduce the diameter of the body of the stud hence giving an effectively larger diameter threaded end portion.
It seems that the standard stud meets the criteria of 2.0D stud engagement so it is difficult to see why a longer thread will provide much benefit.
2. Fine Pitch Thread
Fine pitch threads have a larger pitch diameter than a coarse thread and tend to have a higher thread friction torque than a coarser pitch but this is genrally counteracted by the pitch torque change.
This is governed by a simple relationship:
While a fine pitch thread does have a slightly larger pitch diameter, the higher thread friction torque is negated by the pitch torque change. This is a simple relationship:
F = 2•π•M/p
Where
F = Force
π = 3.142
M = pitch torque
p = pitch
Whilst more engaged threads may increase prevailing torque this component is small compared to the total applied torque and for free running nuts there is essentially no difference between a coarse and fine pitch.
Coarse pitch threads have a higher lead angle than fine pitch threads and as the helix angle is a complement to the lead angle the coarse pitcg thread has a have a smaller helix angle than the fine pitch thread.
This means the fine pitch fastener will develop more axial force for a given torque than a coarse pitch fastener. The coarse pitch, however, develops a a more linear displacment for a given angular displacement.
Fine pitches do provide finer adjustment as they advance less per rotation than coarse threads but the higher prevailing friction can make them more prone to allow variation in axial force.
In general the differences in either torque or axial force for a single pitch step is less than 5% so I am not sure there is much practical differences.
3. 12 point nuts with integral washes
I would agree with the reduced space requirement for Twin Plug Motors compared to the standard nuts.
The intergral flange on the nut will increase the friction and hence the required torque for a given load.
I also looks as if the nuts supplied are coated with a dry film lubricant to ensure consistent tightening.
These aspects of the design, along with the fine pitch thread leads me to ask about the difference between the 'Nut Factor' K of this fastener compared to the standard part and the impact this may have on the preload comapred to using a standard nut.
For example an increase of 35% in the bearing area of a nut due to the presence of a flange would typically reduce tha axial force provided for a given torque by around 8%.
I am not sure if there is any difference in the torque recommended for tightening when using these nuts and it would be interesting to strain gauge some of these studs and compare them to the standard components to see if there is a difference in axial force.
I would imagine that carefully ground washers are very helpful in eliminateing any bending moments in the stud and helping to ensure even tension.
galling of nuts onto Dilavar studs is likely to be a function of the coating but also martensitic steels are less likely to gall than Ausenitic Steels due to basic crystallography and surface energy considerations and this observation is a benefit.
Using a Silver Plated Aircraft style fastener or using a suitable dag such as Boron Nitride would eliminate this problem.
4. Guarantee
Is the guarantee against failure of the stud or loss of preload or against pulling out of the case?
My general conclusion is that by simplifying the design of threaded fastener assemblies to a torque-tension relationship, with no mention of rotation angle, displacements, or strains does not fully address all of the relevant issues.
I still believe that the best 'fix' is to install case savers/timeserts and to install the studs in a well controlled environment in a consistent manner.
I am sure that many of the high quality aftermarket studs are manufactured to better tolerances and standards than stock parts and may help eliminate some of the issues.
Old 12-27-2011, 03:53 AM
[edit]
I believe one of the main drivers behind this was to eliminate the need for careful
control of the axial position of the studs on installation. Instead of "Install to an exposed height of xxxx mm," you run them in until they bottom; the install height is automatically controlled.
I find that appealing from a DIY perspective; one less thing to worry about.
$0.02
Old 12-27-2011, 06:57 AM
$0.02
Mmm!
Tricky - if you bottom out a stud into an aluminium cylinder block the differential expansion that occurs can make it easier for the thread to pull out particularly if the preload is relatively high.
There are also issues to do with any remaining cleaning liquids causing a hydraulic lock and causing varying preload/torque relationships.
It is not really good practice to bottom a stud - it is much, much better to install them correctly and not worry about them pulling out later.
Old 12-27-2011, 09:58 AM
