1980 911SC Head stud choices
I know Pelican Parts sells different varieties of head studs, should i just go with the Canyon brand steel studs? Pelican Parts - Product Information: 10-0115-101-M105
I don't know how good those studs are, any advice would be much appreciated.
Old 01-26-2012, 12:55 PM
I don't have any knowledge about how good the Canyon studs are... but if price were very important I'd probably opt for the OE steel (which are $2 cheaper to boot)... You also really should use new nuts and washers... 24 of the Canyon studs with OE nuts and washers are almost $500...
Then I consider that Supertec's complete head stud kit is $660 (at PP), which, for something so vital did not strike me as that big of a big price delta. I ended up choosing Supertec and actually just got them this week.
OE steel studs for a stock rebuild are by all accounts good enough, but I wanted the extra degree of "bulletproofing".
Old 01-26-2012, 02:47 PM
Supertec
Tell it like it is or don't tell it at all.
Old 01-26-2012, 03:53 PM
If you are doing a stock rebuild, OEM steel replacements for the lower studs will be sufficient.
PM me if you would like a set.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 01-26-2012, 05:12 PM
CaptainCalf's Avatar
Originally Posted by tom1394racing View Post
If you are doing a stock rebuild, OEM steel replacements for thew lower studs will be sufficient.
+1
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD
1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD
2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha
Old 01-26-2012, 05:31 PM
KTL KTL is online now
Schleprock
KTL's Avatar
When using factory studs with coarse threads, if the inhex nuts remove cleanly (threads and hex tooling) there's no reason not to reuse them. The big sturdy flat washers are very robust. No need to replace those either.
Kevin L
'86 Carrera "Larry"
Old 01-27-2012, 01:28 PM
Supertec, lifetime warranty, the way Porsche should have made them. If OE is sufficient why is there so many versions anf improvements and then back to zero? I have had them "ping" off sitting still with no one near them.
Old 02-05-2012, 02:57 AM
