faverymi's Avatar
ARP rod bolt clearance problem???
Good morning
First bump on the road. Rookie in trouble.
I switch to ARP rod bolts. They were installed using the torque method by ARP.
After placing the crank assembly on the R case and test a little rotation the bolt hits part of the case. I know the connecting rod is moving free and probably not perpendicular to the base of the case plane. So I hold it and barely clears the case while rotating the crank.
The bolts in place.
This is where hits. You can see the mark
Another view.
Do I have to worry? Maybe I'm been too rookiesh overly cautious ? If I have to grind the case I rather do it know and not after I placed the P&C.
Any help and thoughts will be greatly appreciated
Thank you, Felipe
RSA Pinky Helga Turtle
Carrera Luigi CDtdi
Old 02-05-2012, 07:24 AM
Try not, Do or Do not
Henry Schmidt's Avatar
WE use ARP rods bolts all the time with no clearence issues what so ever.
I believe you are just seeing a rod positioning issue.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-05-2012, 07:46 AM
faverymi's Avatar
Thank you Henry!
That was fast. Now I'll go back to work.
Carrera Luigi CDtdi
Old 02-05-2012, 07:56 AM
