After the next project
Help with engine stand mounting with P201 from Pelican
Here are two pics. The first is of the engine stand adapter from pelican. It slides into two of the studs from the transmission and allows for multiple screw points from the engine stand to secure.
Questions: - Is two mounting points adequate for a 2.4 liter motor... is it ok since the adapter plate rests flush against the motor which makes the entire thing much stronger? - In the second picture you will see a harbor freight engine stand for 1,000 lbs. Do I use the black provided swing arms and put a bolt through them into the other holes on the Pelican engine adapter? - Lastly, do i use a spacer and just tighten the Pelican engine adapter against the motor using those two studs from the trans Will I be all set if I do these three things above? Thanks in advance for the help. Cheers, Bryan ![]()
Current cars: 2012 Cayenne TT, 1997 993TT, 1912 Buick Model 34, Audi S8, 1976 912E, 2016 Cayenne Diesel |
Mike
Michael Caterino Clemson, SC 1970 tangerine (=Tiger Orange) 'T' targa restoration: mk911.blogspot.com |
Thanks Mike, very helpful. I will purchase some bolts tomorrow and get her in the air for minor disassembly.
Regards, Bryan
I was able to get all four arms to line up by drilling an additional hole in two of the arms.
regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Spiderman
I wouldn't remove stud, just space out and use the nut. Think about it, once tight, there is nothing "lateral" happening to that bolt. Its all tension. Thats whats holding the tranny to your car successfully all day long. It won't fall off if tightened.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
Thanks guys.
I was very lucky and after several attempts of rotating assembly around and playing with the arms I was able to get 3 arms attached without drilling any new holes. She holds like a beauty.
Very clean motor... and almost new (2,500 kilometers) but need to replace valve guides and seals due to bad carbs and washing with fuel... now that carbs are rebuilt, she will be good to go in a few weeks. Thanks for the help, Bryan
Mo money = mo parts
I have a nearly identical set up and was able to get all four by rotating the stand 90 degrees to the engine's orientation. It's hard to state that clearly, but hopefully the picture does a better job.
Greg 86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten 65 Ducati Monza 250 & 66 Monza Junior (project) "if you are lucky enough to own a Porsche, you are lucky enough" |
