Where are the '78-'79 8.5:1 pistons and cylinders?
I'm rebuilding my 1978 911's engine to stock specs. By my inexpert eye, the Mahle nikasil cylinders should not be reused. Vertical scoring visible in all of them. 1978-79 pistons and cylinders are not even listed on Pelicanparts... not even an entry with NLA. On ebay, there is actually one seller currently listing these. But, just one, whereas there seems to be several listings for 1980-83 9.3:1 sets. Are these that rare? Does no one want them? Do people just drop in 9.3:1 sets keeping the early big bore heads and call it a day? What's the story? Couldn't find much comment of the forum about this.
I understand nikasil can be replated. Is that the way to go? Brett |
Brett
The Mahle Nikasil sets come up for sale from time to time. The 8.5 CR are most common, the 9.3 CR a little harder to find and the 9.8 CR Euro almost impossible to locate. The 9.3 CR sets you are seeing on EBay are likely Kobelschmidt Alusil. You can post a WTB ad on the classifieds to see if anyone has a good Nikasil set or you can have your cylinders replated in Nikasil assuming your pistons are good. PM me if you would like more details
Tom Butler 1973 RSR Clone 1970 911E 914-6 GT Recreation in Process |
Put in the 9.3's. They are a drop in replacement. Might want to run premium afterward.
-Andy
72 Carrera RS replica, Spec 911 racer |
ASE Master Tech - 35 yrs
check with EngineBuildersSupply EBS in Reno/Sparks - they do replating as i recall - see their full page ads in Pano
"... I am German, and if it has no logic it's meaningless." 914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Try not, Do or Do not
If you are in the market for a set of pistons and cylinders for your project, give me a call or send an email. We can supply new 8.5:1 Mahles.
We have a huge selection of good used and reconditioned Porsche 911/930 Ps&Cs in stock as well. 8.5:1 Mahles, no problem.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
