Brando
Prove to me that it's possable to
Install rsr shaft seals without shearing them off using the dry method. I feel it's still better that without them but I'm completely confused how you can do it with engine in car.
Why install them dry in the first place? I installed mine oiled and I'm not having an issue. I thought that oiling them was the correct method actually.
Thank you, HFR_Racer '87 930, 3.3 liter, K27 hybrid, Kokeln IC, Andial, B&B, Borla, 17" Supercups. |
Brando
I've been told its the way. Not sure about that with rsr though.
Air Medal or two
use a dab of your flavorit lube...I used silicone..not the type that sets up..
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
Schleprock
I agree with the silicone treatment. It's good practice to use this goop. Because it not only lubricates the seal but adds additional protection from oil aging. The silicone paste is oil and solvent resistant, so it stands the test of time quite well.
Kevin L '86 Carrera "Larry" |
Try not, Do or Do not
We use Dow 55 Silicone Lubricant on all o-rings on air cooled engines.
The commercial product is Dow Corning 111
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
