Brando
quattrorunner's Avatar
Prove to me that it's possable to
Install rsr shaft seals without shearing them off using the dry method. I feel it's still better that without them but I'm completely confused how you can do it with engine in car.
Old 03-03-2012, 12:39 PM
HFR_Racer's Avatar
Why install them dry in the first place? I installed mine oiled and I'm not having an issue. I thought that oiling them was the correct method actually.
Thank you,
HFR_Racer
'87 930, 3.3 liter, K27 hybrid, Kokeln IC, Andial, B&B, Borla, 17" Supercups.
Old 03-03-2012, 04:47 PM
Brando
I've been told its the way. Not sure about that with rsr though.
Old 03-03-2012, 04:58 PM
Air Medal or two
afterburn 549's Avatar
use a dab of your flavorit lube...I used silicone..not the type that sets up..
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 03-05-2012, 07:11 AM
KTL KTL is online now
Schleprock
KTL's Avatar
I agree with the silicone treatment. It's good practice to use this goop. Because it not only lubricates the seal but adds additional protection from oil aging. The silicone paste is oil and solvent resistant, so it stands the test of time quite well.
Kevin L
'86 Carrera "Larry"
Old 03-07-2012, 08:17 AM
Try not, Do or Do not
Henry Schmidt's Avatar
We use Dow 55 Silicone Lubricant on all o-rings on air cooled engines.
The commercial product is Dow Corning 111
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-08-2012, 02:54 PM
