Juggino's Avatar
Send a message via AIM to Juggino
Looking for ideas on how to paint my engine
I have my 3.0 dropped doing a top end rebuild and headstuds. Just cleaned up and sandblasted most of the parts. Anyone have any photos I could get ideas from on how to paint the fan, shroud, etc????
Old 03-09-2012, 07:20 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Black fan ring, silver fan (both powder coat) and amber shroud
Gibbs fan and ring with amber shroud
Gibbs fan and ring with yellow shroud
Black and red ring and fan with red shroud
Gibbs fan and ring with red shroud
Bare metal (aluminum) fan and ring with amber shroud
Powder coated silver ring and fan with black shroud
Black and silver with green shroud
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-10-2012, 11:05 AM
Henry,
Those engines are works of art.
I propose these could be made into a calendar, I would buy one.
-Henry
Sold: 1989 3.2 coupe, 112k miles
Old 03-12-2012, 08:39 AM
I was going to mention re. sand blasting.
I've read one needs to be very careful when using sand blasting around engine parts.
Old 03-12-2012, 08:41 AM
Kartoffelkopf
Spenny_b's Avatar
Agree with above, although some items don't present too much problem, as they don't have hidden cavities. Wouldn't go near grit blasting for things like crank case halves, cam carriers, heads, barrels, etc.
I'm about to deliver a few items for vapour blasting tomorrow (timing chain housings, A/C bracket, Carrera inlet manifold)....less harsh than sand/grit blasting and doesn't damage mating faces. I believe it also has a very mild peening effect of the surface, meaning the items don't go grimy looking if touched with greasy fingers.
Old 03-12-2012, 08:57 AM
I like the peening affect - should keep the surface from getting blochey or as you say covered in greasy finger prints. I have no idea if this is available near me.
Old 03-12-2012, 09:22 AM
Kartoffelkopf
Spenny_b's Avatar
Yeah its the first time I've gone this route...I dropped-off the items to be powder coated last week with one of the regions premier coaters; they had heard of vapour blasting, but didn't offer it as a service, nor knew too much about it.
A 30sec Google later, and I'd found a few companies offering it; thankfully one is only a 1.5hr drive from me, on the way to one of our offices (and they've done Porsche stuff before).
Looks to be more expensive than bead/grit blasting, but I guess you save on not needing to paint/powder coat the item afterwards
Spence.
Old 03-12-2012, 10:00 AM
Kartoffelkopf
Spenny_b's Avatar
Here you go chaps, parts collected the same evening on the way back home from work, absolutely chuffed to bits with them.
UK guys - if you need anything vapour blasting, then Dave @ TSR Vapour Blasting in Sevenoaks is a great bloke; he bent over backwards to help and get them done, to save me having to make a return journey....really good service, unusual these days.
Old 03-15-2012, 10:18 AM
those fall into the over-restored category, too nice to run
Old 03-15-2012, 02:24 PM
Kartoffelkopf
Spenny_b's Avatar
Yeah, I have to say, when I offered the chain housings up to the crankcase yesterday, they did make the case halves look shoddy! Despite hours and hours (...and hours...) cleaning them.
Now waiting for the phone calls from the powder coating and plating shops to go and collect more bling...satin black (30%) covers, which I'm going to polish the Porsche text on, like one of the pics above....hopefully the satin black will look not so much retro but gun "technical".....and dozens of items in new zinc/passivate.
Old 03-16-2012, 02:30 AM
those fall into the over-restored enthusiast category, and are not too nice to run
fixed it for the rest of us
Old 03-16-2012, 04:39 PM
Kartoffelkopf
Spenny_b's Avatar
Originally Posted by eastbay View Post
fixed it for the rest of us :d
Lol....good man, thanks
Old 03-16-2012, 06:44 PM
I went with red and polished throughout....
Old 03-16-2012, 07:19 PM
Old 03-17-2012, 05:39 PM
