Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Originally Posted by KTL View Post
Plain steel OEM studs are plenty good for a std street engine build. They never seem to break.
For future reference, you shouldn't have to grind flats on the studs to get them off with the pipe wrench. A pipe wrench is specifically designed to bite into round surfaces. I know the stud is small in diameter. But if you get the pipe wrench closed down as tightly as possible on the stud, it'll bite. The harder you pull on a pipe wrench, the harder it grips.
Looking at the pictures, make sure to take a look at the input shaft seal on the transmission (behind the shaft tube). That trans housing is very wet looking.
Engine looks like it was really dirty as evidenced by all the dirt on the cam towers behind the valve covers. In hindsight it would have been good to wash the engine before you disassembled too much of it. As it sits now, you have to be very careful about avoiding dirt & crud from getting into places you don't want it.
There's a ton of dirt on top of the case and the heads and towers really need a good cleaning. Doing so will help the engine run cooler. The 911 needs every bit of air cooling you can give it and dirt does a great job of insulating the engine instead of allowing the alloy surface area to do it's job- release heat to the atmosphere.
Nice BMW 540? I had a E39 M5 for a while. Fun car. Way more horsepower than anybody really needs........
Oh yes, it's a 540is in the background...my favorite of the BMW's I've owned. I'll probably keep it until the wheels fall off
Old 06-28-2012, 01:33 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #21 (permalink)
Try not, Do or Do not
Henry Schmidt's Avatar
Stock steel head studs never break but in turn they rarely seal properly with a Nikasil cylinder.
They don't offer a consistent clamping pressure adequate to prevent head movement under load conditions at all temperatures
Without doubt, the Supertec head stud offers the best/most stable platform for all types of air cooled 911 engines.
The engine below was built (by someone else) with steel studs 23000 ago. No studs were loose during disassemble and you can clearly see the head movement.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 06-28-2012, 01:43 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #22 (permalink)
Good job!!!!
You did pretty well dropping the engine by yourself considering this was your very first attempt. Any particular reason why you removed the engine without the transmission? Putting it back would be a challenge doing it solo. One thing I noticed after looking at those pictures was the absence of an engine holder/stand. I'll give you A+ for your effort and determination. Keep us posted.
Tony
  Recommend this thread for the PelicanWiki    Reply With Quote #23 (permalink)
Tony
Thanks. The shop I wanted to use had more than a month long waiting list to take the whole car, but said they could take the pulled engine right away (they only take as many cars as they can shelter indoors - which I like, actually). So, I figured that was all the excuse I needed to tackle a job that's tantamount to a rite of passage for an older 911 owner. The guide I followed suggested an engine only removal and that made sense to me given my objective...and I figured, since I'd be working alone, a lighter load to manage would be preferable. I just moved to a new neighborhood and don't have the sort of neighbors (or relationship with them) that would allow me to ask for a hand, my friends from work aren't the sort to get their hands dirty and the rest of the people I know are all girls (which is fine for everything except engine removal - no offense to any females).
I didn't get an engine stand since the plan was simply to remove the engine and take it to the shop, but my ambition outpaced my planning and before I knew it, I had it down to the block...and now, I'd like to see it through. I recognize that proper assembly is the more nuanced and important phase of the project and have been appreciating all the feedback, tips and advice this forum has provided.
I'm expecting rocker reassembly and cam timing to be the most challenging parts and if, at any time I feel the requirements exceed my abilities and that moving forward on my own might compromise the quality of the build, the shop option is always open to me.
I expect remounting to be really challenging and am working on a more stable way of supporting the engine than the 2x4 and floor jack method that I used for the extraction.
Old 06-28-2012, 06:01 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #24 (permalink)
You've done the most difficult part.........
Ducatist,
You have done the most difficult part of engine rebuilding!!!! That's taking the engine off the car by yourself and doing it with the transmission left behind. You have removed the broken dilavar studs, the rest are easy. If you have the time and interest to do the engine rebuild, I'll strongly suggest you do it. You have demonstrated your ability to do work and the determination to overcome a difficult task. So why deprive yourself the joy and satisfaction of engine rebuilding?
The rest of the engine rebuilding could be done almost sitting down while enjoying your favorite beer during the process. Get a few reference manuals like Bentley and Wayne's Engine rebuild book, some metric tools, etc. and you are on your way to your first engine rebuild project. In case of doubt, simply post a question in this forum and you'll have the answers in your finger tips.
There is really nothing difficult about it if you use care and prudent judgement. The most hardest part is overcoming the fear and anxiety of the unknown territory (engine rebuilding). Once you have decided to do it and take that extra step forward, the rest of the way would be smooth sailing. Think about it before you bring the engine to your mechanic. I will personally assist you in my limited capacity that you succeed doing the project. Keep us posted.
Tony
Old 06-28-2012, 06:47 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #25 (permalink)
83 911 Production Cab #10
JJ 911SC's Avatar
Ducatist,
Tony
+1, when time comes I'm looking forward to it.
All
Please note that no matter what book you have always check for corrections. Here is the link for Waynes one: How to Rebuild and Modify your Porsche 911 Engine: Corrections & Updates
Who Will Live... Will See
83 911 Production Cab #10, Slightly Modified; Slanted, 3.2, SW, SSI, Dansk Sport 2/2, 17" Euromeister, CE Wires, AT Intake... Going PMO EFI + TECgt soon
Old 06-29-2012, 01:25 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #26 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
KTL KTL is offline
Schleprock
KTL's Avatar
Send a message via Yahoo to KTL
Thanks for showing the in-service performance example of the steel studs Henry. Good to know for future service on my engine.
Kevin
MotoDelta sponsored '79 911SC Turbo-Look NASA GTS3
Old 06-29-2012, 09:37 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #27 (permalink)
Engine update
Almost all of the parts are in from our host...should be able to start the reassembly later this week. I damaged a piston during disassembly and had to order a matching replacement (rookie mistake), but otherwise, it's going well. New SS head studs are installed and the rest of my time has been spent cleaning stuff. That carbon buildup on the pistons is a real pain...finally used some POR15 caliper cleaner and wished I'd been using it all along - melted the stuff off quickly.
Old 07-02-2012, 08:15 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #28 (permalink)
j911brick's Avatar
Considering the age of this engine I think it would be folly not to split the case and do a minor refresh. Your going to be real mad if the pick-up tube seal fails next week and you lock the motor up.
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 07-03-2012, 07:30 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #29 (permalink)
I would worry about the o-ring that seals the # 8 main bearing.
With time they get hard and leak, especially after an engine R&R. This leak requires a case split and o-ring replacement to properly repair the leak.
Henry Schmidt
Ph: 760-728-3062
Old 07-03-2012, 08:14 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #30 (permalink)
Thanks again Henry. I appreciated all the time you spent with me on the phone yesterday...your insight and advice were very helpful.
Old 07-04-2012, 09:48 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #31 (permalink)
Speed Buggy's Avatar
I am in about the same spot. Waiting for an intermediate shaft timing chain gear from our host to glue the case together. I also had a damaged piston, (1). Had to go off board to procure that. Does your passenger side oil tray in your chain box have a groove cut in it from the chain? That is why I am rebuilding. Tensioner failure. Aluminum in the engine. Good luck. Mike.
Run like the wind...straining the limits of machine and man... (Peart)
'81 911SC Black on Tan (undergoing motor rebuild), '13 Ford Focus, '13 Dodge Durango (wifeys), '05 Honda Accord Coupe, '03 Volkswagen Passat GLS (sons).
Old 07-04-2012, 11:40 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #32 (permalink)
This may sound dumb but i don't see what you mean by the "movement" from using the steel studs. Please explain!
Old 07-04-2012, 01:01 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #33 (permalink)
JJ 911SC's Avatar
Originally Posted by SergiuM View Post
This may sound dumb but i don't see what you mean by the "movement"... Please explain!
Not really... And I'm also like to hear the details
Old 07-04-2012, 02:11 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #34 (permalink)
As illustrated in post 22, the steel studs offer inadequate clamping pressure to keep the heads from moving excessively. This constant movement results in poor if not horrible head to cylinder sealing. Dilivar head studs show the same type of sealing anomalies under high stress situations.
Henry Schmidt
Ph: 760-728-3062
Old 07-04-2012, 05:38 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #35 (permalink)
Speed Buggy,
Mine had three broken headstuds, but everything else looked and ran fine. My tensioners have the saver collars from our host which are supposed to prevent the kind of damage from tensioner failure that it sounds like your engine suffered.
Where did you end up finding your piston? I've been working with the guys at EBS Racing since last Friday and they told me they're sure they have one that matches mine, but they still haven't managed to actually pull it from stock. I guess the holiday put them behind or something. Hopefully, they'll turn up the piston soon since it's really holding me up. I have the Alusil pistons that some of the builders just throw away rather than reuse, but the guys at Parts Heaven charge $150 per (EBS is only $50) and like I said, some builders just sell them as aluminum scrap. Apparently, my damaged piston is a little uncommon based upon the dome markings.
Old 07-05-2012, 11:38 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #36 (permalink)
Darn. I was planning on spending my money on a set of steel studs, but i guess after reading this I'll have to go with the more expensive high performance studs instead.. I don't wanna risk having problems down the road.
Old 07-05-2012, 05:29 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #37 (permalink)
I got mine at Parts Heaven. Couldn't find anywhere else. I had a couple of maybe's but they fell through. My machine shop recommended P.H.
Old 07-05-2012, 05:56 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #38 (permalink)
Still having no luck finding a matching piston
So far, none of the places I've searched (EBS Racing, Parts Heaven and Henry Schmidt) has a replacement piston to match my damaged one. Buying a whole set seems like overkill and I'm told the difference between a "1" and a "3" piston is less than .001"...so, I'm pondering buying a "2" since no "3's" appear to be available. Either way, I'm stuck until I find a solution.
Here are pics of my piston and cylinder markings...any advice would be welcome.
Old 07-10-2012, 02:40 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #39 (permalink)
Ronnie's.930's Avatar
One thing I would suggest is for you to create new threads, here, in the 911, and in the parts for sale & wanted forums requesting the piston you need. I remember a while back someone needing a piston and a member, maybe MBurns, said he had a wide variety of them . . .
Old 07-10-2012, 02:55 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #40 (permalink)
Tags
dilivar, engine removal, head studs, headstud removal, headstuds
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
