It's a trap...
Speed Buggy's Avatar
Location: 1/2 way between the Motor City and the Glass City.
Reuse cylinder gaskets after deckheight check?
Can I reuse the copper after the deckheight check? Thanks.
Run like the wind, straining the limits of machine and man....
2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys).
Old 09-16-2012, 06:18 PM
base shims
I have no problem with that.
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 09-16-2012, 06:33 PM
Walt Fricke's Avatar
I found that the copper shims/gaskets on a 2.8L 8,200 rpm race motor where squished some - you could see where they stuck out a bit beyond the cylinder, because that part was thicker. These may have been used through many rebuilds when this motor was a 2.2, though. So I decided new ones were in order.
But just torqjuing things without running shouldn't change their thickness. If they don't give the appearance of having been squeezed thinner in spots, I'd not worry at all. In the past I have just reused these on rebuilds. And you could get out the micrometer or calipers and measure them all.
Old 09-19-2012, 10:16 PM
KTL KTL is online now
Schleprock
KTL's Avatar
If Mike has no problem with it, then you should be fine!
I've seen cylinder base shims reused on top end rebuilds. I'm not necessarily endorsing it. Just saying that i've seen it done and the motors have not leaked afterwards. So reuse of the gaskets after deck height check should be no big deal.
Kevin L
'86 Carrera "Larry"
Old 09-20-2012, 08:06 AM
It's a trap...
Thanks, guys.
Old 10-02-2012, 08:30 AM
