Any Use For Complete 2.7?
May have finally located an early car for a hot rod project.
Also happen to have a spare 2.7 complete engine that came with another track car. Does the 2.7 (or parts from it) have any value whatsoever as the basis for a carbed street engine, i.e. can the crank, p/c's, heads be used in conjunction with a later 3.0 or 3.2 case?? I realize that there are some very strong 2.7's out there, however if I ever decide to sell the car I am a little concerned with the perceptions that potential buyers could have with a 2.7 engine. Thanks! Lindy |
2.7
Based upon the somewhat minimal responses (0), unless someone chimes in I guess this is a good enough reason tof orget the 2.7 as a source of useable parts and build that "big block" I've been wanting to do!
2,7 and 3,0 and later cases are different (unless 3,0 Carrera).
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Straight shooter
If you have a good one then save it as backup... if it is numbers matching then I wouldn't separate from the chassis even if it rolls on a cart as a spare when you sell the car.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
