Certifiable
Quicksilver77's Avatar
Send a message via Yahoo to Quicksilver77
Torque Spec Check!!
Hi all, I am in the process of doing a bit of oil leak repair on my 87 930 and was wondering on the Torques spec on:
1- Intermediate shaft cover bolts (no idea on this one)
2- Crank pulley bolt (rumor has it 150 foot-pounds?)
Thanks in advance for sharing your wealth of knowledge!
Sean D. 1987 930
India Red/Beige/Black; Mahle 3.4L; Kokeln IC; K27 7200; GHL Headers; Borla Stainless Muffler; SC cams; Sachs Aluminum Clutch; Aluminum flywheel; Bilstein Sport Shocks; Adjustable Rear Sway Bar; Weltmeister Shock Tower Brace; Lowered and Corner Balanced; MOMO RSGT Seats...
Old 10-16-2012, 11:38 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Intermediate shaft is snug and that's all. The sealing is done by the o-ring on the cover. If you really want to torque it, get out your in-lbs torque wrench and torque it to 6 lbs/72 in-lbs. That's plenty.
Crank pulley bolt depends on whether or not it has A/C (double pulley) and what type of bolt. There are two bolts used:
1. Typical M12 bolt with a spring washer under it.
2. A serrated flange head bolt. Called Durlok. The thing grips like a bulldog and can sometimes be a real SOB to get loose.
Kevin L
'86 Carrera "Larry"
Old 10-17-2012, 11:59 AM
Certifiable
Thank you very much Kevin!
I will be fighting the the bulldog on this one...
Sean D. 1987 930
Old 10-18-2012, 04:00 PM
Certifiable
Well the Durlok Bolt yielded with a long breaker bar... Cleaning the area, pulling the old seal and then reinstalling the new seal.
Question is... As the seal sits now it is outboard of the case by roughly 1/8" for the new seal should it be flush with the case? Perhaps it will be obvious when I remove the old seal?
Sean D. 1987 930
Old 10-23-2012, 09:17 PM
Schleprock
KTL's Avatar
Maybe when someone replaced the seal, he thought it should stick out a bit to get a "new" surface to seal against? I'd prefer to seat the new seal flush or just a hair deeper instead. My thinking is that the surface of the crank is cleaner further into the engine, simply because it's been sealed inside the engine case for a long time. The exterior surface of the crank has been exposed to the elements for a long time and doesn't have as smooth of a sealing surface.
Kevin L
'86 Carrera "Larry"
Old 10-24-2012, 07:49 AM
Certifiable
Stellar! In and done! now off to have some oil hoses rebuilt and then I can start on the engine wiring harness that opened this can of worms! Thank you for the knowledge!
Sean D. 1987 930
Old 10-24-2012, 03:01 PM
Smart quod bastardus
fredmeister's Avatar
You may have the classic leak we all love that is not from around the crank seal but from the o-ring inside the case around the #1 crankshaft bearing.
I thought the crank seal was leaking and replaced it but this did not solve the problem for me.
If that's the case for you, there is a retrofit kit that you can install to dam up the or-ring leak, and this avoids cracking the engine block apart to replace that silly crank journal o-ring.
Good luck,
Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 10-26-2012, 07:27 AM
Certifiable
Thanks for the heads up Fred! I think I read up on that leak that you are mentioning, is it the kit by Tom Amon(sp) that you are referring to?
Sean D. 1987 930
Old 10-26-2012, 10:15 PM
