fastfredracing's Avatar
930 Oil pump in early case, what did you do for a sump plate?
I grabbed an early sump plate that is concave, with no drain plug, but I am still getting slight contact with the Turbo Oil pump screen.
Anyone used one of the Mainley sump plates that our host sells? Looks like they have a slightly deeper recess. I like the factory style plate better for asthetics though.
I was also thinking of just shimming my factory style plate down with an old sump screen with the screen removed, and two gaskets .
Would like to hear some of your solutions .
No left turn un stoned
Old 10-23-2012, 07:07 AM
sjf911's Avatar
I have one and it also contacts the pump screen.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 10-23-2012, 08:43 AM
KTL KTL is online now
Schleprock
KTL's Avatar
I have a Mainely and it's a very nice pice. Also comes with a magnetic drain plug which is nice. It clears my 964 pump (similar screen dimensions as 930 pump) installed in a SC case no problem.
Supertec & Rennworks also make a nice vintage looking aluminum sump plate.
Both of the plates are in Pelican's catalog Porsche 911 Oil Circulation - Page 7
Not a bad idea to shim it down if you want to. Also not a bad idea to remove the screen. As they get older, the screen can sometimes break free of the flange.
How often do you open up your sump plate?
Kevin L
'86 Carrera "Larry"
Old 10-23-2012, 12:41 PM
