3.2 Cylinder to Head Seal
I am in the process of assembling the heads to the cylinders. Is there any special treatment required on the sealing faces.
Bill
Old 10-31-2012, 08:16 AM
KTL KTL is offline
Schleprock
KTL's Avatar
No treatment needed. Clean and dry.
Kevin L
'86 Carrera "Larry"
Old 10-31-2012, 08:35 AM
Thank you. Since this is a metal to metal seal shouldn't there be a surface finish and flatness requirement?
Bill
Old 11-01-2012, 03:52 AM
There is a bevel on the top of the cylinder. Between the bevel and the torque requirements you get the seal.
Bruce
Old 11-01-2012, 05:20 AM
Some people like to lap the heads to the cylinders with some valve grinding compound and then of course clean it off before assembly.
I'd like to hear more opinions on this too, and if it's a good idea with heads that have been resurfaced and new mahle 930 pistons and cylinders without flame rings.
Old 11-01-2012, 08:13 AM
