Where do you guys get your Dow 55 or 111 locally?
Thank you.
1983 SC
Blog
Old 11-28-2012, 12:01 PM
KTL KTL is offline
Schleprock
KTL's Avatar
McMaster Carr. I have one in my region so it's like having a local hardware store. I order something this afternoon and it shows up on my doorstep the next day before lunch. If you're using it for o-rings, you want 111 or 112. 55 is not silicone friendly and its twice the price.
Kevin L
'86 Carrera "Larry"
Old 11-28-2012, 02:05 PM
Yeah, looks like I'll have to order it.
Old 11-28-2012, 06:19 PM
johnman001's Avatar
I found it in a local motorcycle shop. They also had the 3bond I was looking for. They were less than 2 miles from the house and I figured I would give them a try. Glad that I did.
John Flesburg
2016 981 Boxster S.................| 1983 911 Turbo - (White)
1974 911 3.2 - Red Car........... | 1974 914-6 3.2 - (Silver)
1974 914-6 3.2, GT -(Red).......| 1974 914 - 2.7 GT Clone (TBD - Saphire?)
1971 914 (TBD)..................... |
Old 11-28-2012, 08:05 PM
The Dude abides...
bigel's Avatar
I didn't know that McMaster would make local (residential) deliveries...good to know.
'03 Carrera 4S
Old 11-29-2012, 03:19 AM
Try not, Do or Do not
Henry Schmidt's Avatar
.......edit......... 55 is not silicone friendly and its twice the price.
We've been using Dow 55 for o-ring lubricant for years with no negative effects.
"Dow Corning® 55 O-Ring Lubricant is a soft silicone-based grease, slightly swells rubber for better sealing, oxidation resistant and serviceable over a wide temperature range. Used for dynamic lubrication and sealing between rubber and metal parts in pneumatic valves. Typical applications are found within the aircraft, automotive, paintball and other industries."
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 11-29-2012, 08:14 AM
johnman001's Avatar
McMaster Carr does not deliver, but UPS does.
John Flesburg
Old 11-29-2012, 10:10 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Good to know Henry's had great success with 55. Those with much less experience are probably better off erring on the side of caution, since all silicone is not the same and most people don't know what type of material makes up their o-rings? So I said not silicone friendy just to be safe.
http://www4.dowcorning.com/DataFiles/090007c88033c335.pdf
COMPATIBILITY
Molykote 55 O-Ring Grease has
been shown to swell natural rubber.
However, compatibility of the
lubricant may vary with the
plasticizer content of specific
materials (especially elastomers).
Small-scale compatibility testing
should be conducted prior to the
use of this product in any
application.
Molykote 55 O-Ring Grease should
not be used with the following
materials unless thoroughly tested
for your specific application:
 Silicone rubber (SR)
 Polycarbonate (PC)
 Acrylonitrile-butadienestyrene (ABS)
 Liquid oxygen (or other strong
oxidizers)
Kevin L
'86 Carrera "Larry"
Old 11-29-2012, 10:40 AM
For what it's worth, I originally used the government-spec 55 from Henry's sealant kit. There was enough for one only application on each o-ring (at least the way I was smearing it on), and unfortunately I find myself having to split and assemble the case a second time.
I would like to recommend he create a #$%@-up kit that contains a little extra 55 for the novice and inept among us...
1983 SC
Blog
Old 11-29-2012, 11:07 AM
